Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 9th July 2007, 08:28 PM   #1
Shpoop is offline Shpoop  United States
Default Help removing paint
hey guys. i need help removing paint. It's not on audio boxes or anything so I put it here.
I'm talking about paint on glass bottles. For instance, something like shown below.
I've tried paint thinner and acetone. Neither worked. I didn't soak, I dipped paper towels in the solvents and then scrubbed. Should I try soaking next? I don't think that would make a difference, because nothing at all visible happened with the scrubbing.
Does this type of paint require a different type of solvent? Any ideas?
Thanks!
Old 9th July 2007, 08:40 PM   #2
edit:
I've also tried washing it and scraping it with a knife (tho probably not as sharp as window razors), as well as scrubbing it with steel wool. Neither worked.
maybe it should be mentioned that the glass I'm trying this on is frosted.
Old 9th July 2007, 09:06 PM   #3
Hartono is offline Hartono  Indonesia
Hi Shpoop,
maybe it wasn't paint ? if it's that tough probably the letter/picture use some sort of colored glass.
Old 9th July 2007, 10:53 PM   #4
Chartal is offline Chartal  Canada
Maybe you can try furniture paint stripper.
Old 10th July 2007, 12:48 PM   #5
KP11520 is offline KP11520  United States
KP11520's Avatar
Hi Shpoop,
Do you have any firends that work at a Car Radiator shop? They have a tank that removes paint from radiators with a caustic solution so they can recondition them. Bring a six pack (or a case) of beer and ask them to soak it for a couple of days. Or find an Automotive Paint supply house and ask them what they would use to remove the paint. Good Luck!
Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner?
Old 22nd July 2007, 04:46 PM   #6
If it's already frosted then would a very fine media sandblast not work just fine?
mdf paint joshuajoshua Multi-Way 16 8th September 2008 02:36 AM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
Paint finishing?????? bostonswoop Everything Else 19 3rd February 2006 02:42 AM
Page generated in 0.08008 seconds (78.90% PHP - 21.10% MySQL) with 10 queries
