| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I just fried a PC motherboard (pain)... the meltdown took a couple of transistors (two n-channel MOSFETS in parallel... ST B40NE03L-20 if anyone wants to spare me finding some replacements) and a couple of electrolytic caps. Now, the thing is it seems like a not too complicated fix to perform, but i can't unsolder the darn things. They use the "d2pak" packing, where the drain is the flat side of the transistor and it's soldered directly to the board. Any ideas?
#2 |
Hi Lisandro_P
With a good soldering iron this shouldn't be a problem. It is possible that the transistors are glued on the board. Don't know if they do it with the bigger ones. So you will have to pull a bit when the tin is melting. We also use desoldering wick to take off the old tin. Tip: never reuse SMT's./Hugo - Likes to make pictures. |
#3 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#4 | ||
#5 | |
BTW i managed to pull one out (just stuck the soldering iron to the exposed metal and pulled a bit with a screwdriver), but the other one's so tricky... |
#6 |
To desolder: first the legs, heat them, apply a bit of fresh solder and then lift them when the solder is melted with tweezers (that you put under the leg, they break off sometimes). Then heat the tab, also applying a bit of fresh solder. Clean up with the solder wick (make sure you get every bit) and then clean with isopropyl. When soldering the new one, first the tab, then the legs and keep the tab flat on the pcb, heat well so that the solder can flow under the tab (use flux).
Now a fried smps is not simple to repair! I spend this afternoon trying to get one running again and it keeps blowing. Replace only by the same fets! A bigger one may seem nice, but the gate capacitance may be too large. This will lower the efficiency (if it does not affect stability), making everything even hotter. The capacitors are also critical components. They must be low esr and rated for the ripple current at operating temperature. |
#7 |
Banned
Hi all,
For what it is worth from my 5 day a week experience have a look at my method: http://db.audioasylum.com/cgi/m.pl?f...so&r=&session=
#8 |
Just brought two replacements: a pair of IRF530. Those were the closest in specifications to the old (discontinued) mosfets, and they double the voltage ratings. I just hope it works
Thanks for all the feedback guys! |
| Surface mount DIP Sockets? | ROBSCIX | Parts | 6 | 18th June 2007 03:23 PM |
| WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x | Destroyer OS. | Swap Meet | 1 | 22nd December 2006 06:18 AM |
| Surface Mount equipment | rtarbell | Parts | 0 | 29th March 2006 01:40 AM |
| surface mount adapters | audioferret | Parts | 2 | 30th November 2005 08:38 PM |
| Surface mount is more fun than... | PSz. | Chip Amps | 0 | 9th April 2004 10:43 PM |
| Page generated in 0.10532 seconds (78.62% PHP - 21.38% MySQL) with 11 queries |
