| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
i have a normal stereo/cd player in a bar where i live and the bar man has hooked 2 extra speakers to the o/p for the front seating area.
the trouble is, the original speakers are large 2 way and the extra are small cheap single drivers. obviously there is an impeadance problem The problem i have is that the outside (small) speakers are NOT as loud as the original pair on the inside. Is there a simple way i can feed the stereo output to an unit that has two volume controlls 1 for each pair. i would appreciate a simple non HI-FI spec solution as out here ive been quoted 250 to 350 dollars !!!! i can get most electronic components easily and can construct cct's no probs. any help appreciated thanks. john |
#2 |
Not enough info to solve problem.
1. power output of audio amp 2. minimum/nominal recommended Z of speakers 3. Z of pair 1, recommended min/max power levels 4. Z of pair 2, " 5. Are preamp outputs available? 6. How are the speakers hooked up now? Are they phased properly? Devices called L-pads can sometimes be used to control speaker volume at the speaker leads. Z matching can sometimes be done with resistors and/or just parallel/series combinations of the speakers/L-pads. It may or may not be a suitable solution. |
#3 |
buy a power amp for each set of speakers. Preset the gain in each amp to give a suitable relative volume from each speaker. Then use the source volume control for overall volume changes.
regards Andrew T. |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| multi-channel volume control | Chispa | Solid State | 13 | 17th April 2007 07:34 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Multi-Channel Volume Balancing | Firebug24k | Chip Amps | 3 | 22nd February 2005 06:13 AM |
| Multi Deck volume pot | A3rd.Zero | Everything Else | 14 | 26th April 2004 06:23 PM |
| Page generated in 0.06788 seconds (72.88% PHP - 27.12% MySQL) with 10 queries |
