| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello, I was so lucky, that i got a '' pro alucut 80teeth ø254mm '', and i have tried to attach it to an '' Variac 0-230 transformer '', so to lower the rpm's to around 1700rpm, for idle cut with this circularsaw.
Well it's working allright, but the problem is, that the saw is loosing some power when doing it with a variac. Does anyone here know how the regulators on pro circular saw's work ???, ore another cheap way of doing this ??? I have attached a picture of my saw, and i think it's a serie motor, where the 'stator windings' is in serie with the 'rotor' via the brushes. EDIT : It's for cutting Alu ofcause
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp. |
#2 |
A servo controlled variac or rheostat is an option. Ideally what you need to do is to lower the ac frequency. This is complicated.
I think what you could do is shunt hot threw a 0.065ohm shunt. As the current increases (motor load) the voltage drop over the shunt will raise. Rectify and filter this drop, add a bias (speed control), and use it to control a TRIAC. I thought of that all be myself ![]() Edit : Wait, no rectify? |
#3 | |
Speakerholic
#4 |
I dunno about controlling the speed: But I'd lose that glove - it's more danger than protection IMHO.
Crazy Yankee. |
#5 | |
Hear the real thing! |
#6 |
When it comes to AC motors like power saw motors, the RPM is determined by the frequency of the local power grid ... usually either 50 or 60 Hertz / cycles per second.
Trying to control the RPM of an regular AC motor by using a Variac can be quite dangerous ... not only will the RPM get out of control (while trying to stay within ~ 85% of "ideal", synced grid based RPM) the power will become erratic and "drop phasing" with the power grid = intemittent speed changes and power fluctuations = burned motor windings or worse. Most AC motors with variable speed controls use a switching power supply that takes the grid power and frequency and converts it to a pulse width modulation AND frequency variation to achieve speed / RPM control ...
Over compression is a problem with modern CD recordings |
#7 |
Most power tools have a simple scr or triac speed control in them. Usually this circuit senses load and increases output to compensate. The motor on this saw should be a universal type so it could be run off of dc or ac. The hardware stores here sell replacement variable speed triggers for power drills for around 20 USD. I would think you could wire one to the saw and make an adjustable stop to set speed.
Dremel used to sell a plug in box to do this, I do not know if they still sell them. I think there are some schematics for such things on the internet. Need a big scr, a few resistors, a couple of caps, and a rheostat. Regards, Steve
Finding new ways for the extreme mis-application of high tech! |
#8 |
thanks for all the answers.....
#9 | |
The motor could be run of a dc-regulator i am sure, but i don't know how much it would need then. Actually the best (And most expensive) is ofcause a real freg. converter... About lubrication, i am interessted in knowing more !!! Jesper
#10 | |
Just control the voltage: triac, variac or whatever you got. You can even run it perfectly fine with dc, it spins right direction even with reverse polarity. |
| WTB: 60+ way circular connectors | mobyd | Swap Meet | 0 | 19th July 2007 10:21 AM |
| RTR DR-1 (circular electrostatic panel) | enilsen | Planars & Exotics | 25 | 4th May 2007 12:07 PM |
| What's the deal with the circular disc's......... | Rick J. B. | Full Range | 9 | 1st January 2007 03:30 PM |
| circular radiating speakers | nutcracker | Multi-Way | 1 | 13th February 2006 08:20 PM |
| Page generated in 0.11329 seconds (80.30% PHP - 19.70% MySQL) with 11 queries |
