Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Power amp case faceplate, you like aluminium or wood ?
Old 27th June 2007, 02:05 AM   #1
gaetan8888 is offline gaetan8888  Canada
Default Power amp case faceplate, you like aluminium or wood ?
Hello
For commercials or diy amps, it's mostly made in aluminium and only few are made with woods. Things are changing ? or aluminium will continue to be the most popular ?
For a power amp case faceplate (or chassis front Panel), what do you prefer, aluminium or wood ?
For myself I like woods faceplate.
Thank
Gaetan
Old 27th June 2007, 02:12 AM   #2
Cloth Ears is offline Cloth Ears  Australia
Cloth Ears's Avatar
Black anodised aluminium.
Wood is 'pretty', and makes each item unique, but for a power amp I look for 'fade into the back-ground' black.
Now, pre-amps... Jarrah! And I'd like to replace the fromt panel of my Marantz tuner with reddish-blonde Tasmanian Oak...
But all my stuff is basic black except the afore-mentioned tuner.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 27th June 2007, 02:16 AM   #3
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Can't beat aluminum...
Old 27th June 2007, 02:38 AM   #4
tubewade is offline tubewade  United States
tubewade's Avatar
Each can look nice in their own respect. For valve amplifiers, with exposed chassis on the top, I like natural wood sides or wooden base altogether, but for solid state with nothing pretty to see I suppose aluminum, anodised or brushed, is OK. I have made preamps with wooden ash front panel painted delicate black and it looks really nice. I've never seen a preamp with a natural wood front panel but it might look nice too.
Wade
Old 27th June 2007, 04:09 AM   #5
Conrad Hoffman is offline Conrad Hoffman  United States
Wood is probably questionable with regards to regulatory requirements on safety (flammable) in most countries. I can see commercial manufacturers avoiding it for that reason. Some years ago, it was common for receivers to have wooden covers, with just some metal perf screen for ventilation. Now even wood side panels are rare. My preference is for aluminum chassis' with standard 1/8" aluminum rack panels.
Old 27th June 2007, 08:11 AM   #6
XEAGLEKEEPER is offline XEAGLEKEEPER  United States
XEAGLEKEEPER's Avatar
Can't beat aluminum
Yes you can..but that leaves ugly scratches and dents...
Anodised is the way I went http://www.par-metal.com/
Series 12.
Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 27th June 2007, 08:43 AM   #7
R.I.P.
there are a few up-market units with sculpted wood facias. They can look very good.
I do not see a safety problem other than fuel for a fire. By then your fusing has failed to do it's job.
regards Andrew T.
Old 27th June 2007, 11:09 AM   #8
Certainly risks are low for a wood front panel, but in today's regulatory and legal environment, any risk that can be reduced from low to non-existent, likely will be.
Old 27th June 2007, 01:21 PM   #9
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
Are wood and aluminum the only options?
I_F
Old 27th June 2007, 11:12 PM   #10
Cloth Ears's Avatar
I_F
Glass, plastic, ceramic - but each brings their own set of problems (eitehr with longevity or with the initial working with them).
Jont.
Power amp case faceplate, you like aluminium or wood ?Hide this!Advertise here!
Any photos of power amp case wood faceplate ? gaetan8888 Everything Else 4 6th August 2007 11:38 PM
making rectangular holes in aluminium case AdamZuf Everything Else 7 23rd November 2006 03:39 PM
Hot glue on wood case for mounting? Dominick22 Chip Amps 6 14th June 2006 10:12 PM
Wood case for amp. dhenryp Chip Amps 5 3rd August 2003 03:52 PM
wood/metal laminate for case mltaunt Everything Else 5 7th November 2002 05:48 PM
