Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 26th June 2007, 05:29 PM   #1
Default TL 494 in linear mode?
Hi all!
Experimenting with SMPS power supplies I've came with a -not so- crazy idea: can you use a TL494 in a linear mode power supply?
I mean, you have already 2 interconnected op amps, one for voltage, one for current monitoring, and a nice band gap voltage reference.
Use the feedback output to drive a npn external transistor, witch in turn drives a power pass and you've done!
Will it work? I don't see no drawbacks here...
cheers!
EL84 in ultra-linear mode cs Tubes / Valves 8 21st September 2006 03:50 PM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 09:15 AM
Mullard 5-20/Maplin 4-20 modification to NON-Ultra Linear mode???? vinyvamos Tubes / Valves 1 28th January 2006 04:07 PM
Calculating watt requirements for multi-mode/tri-mode operation? Datoyminaytah Solid State 1 14th August 2004 07:43 AM
Switched Mode vs Linear Power Supply royalmp2001 Solid State 4 12th July 2002 08:04 PM
Page generated in 0.06036 seconds (67.34% PHP - 32.66% MySQL) with 10 queries
