Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Cabinet cooling
Cabinet cooling
Old 31st May 2007, 11:38 PM   #11
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
You won't hear much difference in the noise level, but 12VDC fans can be run from 6-8 V for quiet operation. Some won't start reliably at 1/2 the rated voltage, so you'll need to play around to get a combination of reliable starting and quiet operation.
If you had used pots on the 117VAC fans you'd more likely have burned up the pots than the fans.
I_F
Old 1st June 2007, 12:13 PM   #12
quasi is offline quasi  Australia
quasi's Avatar
The best way to slow down a mains rated fan is to connect a mains rated capacitor in series with it. This way you will use the reactance of the capacitor to drop the voltage without generating any heat.
I would try a 1 uF capacitor first and see what the effect is and then experiment up or down from there. You can also parallel or series capacitors you have to get the value you need. Larger capacitance = faster fan.
Be sure to connect a 100 Kohm (or anything near that) 1/2 watt resistor in parallel with the capacitors to discharge them when the power is turned off, otherwise you might get a nasty surprise if you ever touch one (even days after it was last turned on).
The cheapest place to find these capacitors is inside discarded PC power suplies, old TV's etc.
Using this technique mains fans can be slowed right down to almost absolute silence and still deliver enough air to make a difference. Just make sure that the fan will start reliably every time.
Cheers
Quasi
Old 8th June 2007, 12:50 AM   #13
ak_47_boy is offline ak_47_boy  Canada
I have been thinking about how to get rid of tube heat lately, it is quite hard. The hard part is; Can't loose central air out chimney in the summer.
The only alternative to a chimney/fan would be a high temp/high btu air conditioning system in your cabinet.
Cabinet coolingHide this!Advertise here!
2 air way fan cooling on amp? 2fast Chip Amps 6 5th June 2005 05:07 PM
fan cooling? Raj1 Pass Labs 22 8th January 2003 03:33 PM
Cooling an amp with poor cooling BAM Solid State 8 31st December 2001 05:40 AM
