Strange surplus find...time-machine?? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 24th May 2007, 10:18 PM   #11
redrabbit's Avatar
Thanks gootee.
Looks like I'll do more research...good links you gave there.
(I'm also considering that Wave Analyzer kit.....hmmm...)
The only numbers on this thing, are hand inscribed, on various parts, like:
WP 12492
FP 3278
FU 1256
One thing to think about....why is there a plastic shield/window ?....
....meant to be viewed ? otherwise, I'd think a metal housing would be in it's place.
=FB=
Old 25th May 2007, 04:01 AM   #12
gootee is offline gootee  United States
Originally posted by redrabbit
Thanks gootee.
WP 12492
FP 3278
FU 1256
=FB=
If the unit were viewable, it might be a plus to be able to see inside, too. But it might also just be a lightweight way to have a "dust cover", to keep dirt and some moisture out, but also to protect the internal rotating parts from mechanical interference (and maybe even to help keep their sound inside, if it went on a submarine).
It would be interesting if you could see if there are any voltages on the connector pins, when it's activated.
- Tom
Old 25th May 2007, 04:17 AM   #13
OzMikeH is offline OzMikeH  Australia
does the brass looking thing have flyweights?
do the weights swing in and out depending on speed?
if so then it may be a speed regulator of some kind.
it might be a generator or a DC motor if you measure voltage.
Old 25th May 2007, 06:32 AM   #14
redrabbit's Avatar
Yes to all questions.
* This surplus store (Apex) contains many older aircraft parts.
* The bottom metal housing only contains wires to the 4pin connector - no motor.
* It will produce up to 1v dc, depending on spinning speed.
* The top contacts make alternate contact as it spins. It's a 1 pole, 2 contact arrangement, connected to 2 connector pins (and elsewhere inside).
* What I said was maybe a capacitor....could that be "reading" the counter weighted part? (a Reed relay?)
* There is a space on the top gear for a belt.
I made a drawing:
http://i5.photobucket.com/albums/y17...t/DSCN2109.jpg
I think it may be a speed indicator that does not rely on any other power but it's own..??
=FB=
Old 25th May 2007, 06:42 AM   #15
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The construction is not rigid enough for sub use.
There are likely pictures of gyro valves for torpedo tubes to be found on the web, they're built like a brick.
Military aircraft looks more apparent, i recollect the cash prize for weight saving idea box sweepstake like it was yesterday.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
1939 Radioshack Catalog online...Anyone have a time machine? m6tt Tubes / Valves 12 9th December 2008 03:49 PM
Strange find.. help ID? cwujek Tubes / Valves 10 15th January 2008 08:44 PM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
SMD machine? lumanauw Equipment & Tools 7 26th December 2004 12:46 AM
Brazil, and some strange laws, not too much strange! destroyer X Everything Else 0 11th September 2004 12:38 PM
Copyright ©1999-2017 diyAudio
