Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 9th May 2007, 02:44 PM   #1
SharpyWarpy's Avatar
Default Correct load impedence
I'm a newbie so please bear with me here.
I have a Sony surround sound amp. I wanted to improve the quality of sound when listening to music so I built a set of speakers. I have two drivers per enclosure wired in parallel, they are 4 ohm drivers. It occurred to me this makes the load impedance 2 ohms. Should I put a 2 ohm resistor in there to bring the load back up to 4 ohms? Would it be better to wire the drivers in series, or would that not work properly? Thanks.
Old 9th May 2007, 02:53 PM   #2
Speakerholic
Cal Weldon's Avatar
Are these full range units?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 11th May 2007, 07:31 AM   #3
I''m sorry, I don't know what you mean by "full range". Where can I find terminology of speakers? Thanks.
Old 11th May 2007, 07:31 AM   #4
Okay, never mind, a quick Google search tells me "full range" means the drivers are capable of producing the entire audio range, which in my are case they are.
Old 11th May 2007, 03:47 PM   #5
Speakerholic
Cal Weldon's Avatar
I would try running them in series.
Old 11th May 2007, 04:32 PM   #6
Hartono is offline Hartono  Indonesia
given the choice of serial connection or parallel+resistor connection :
1. If you do connect in parallel+2 ohm resistor, your resistor will dissipate a lot of power and should be rated accordingly (watts) ,plus you will lose 50% or more power in that resistor. without the resistor the load will be to hard for amp to drive. meaning not good for amplifier life.
2. I agree with Cal Weldon, I also recommend series connection.
Old 12th May 2007, 12:39 PM   #7
Thanks for the replies.
I rewired them from parallel to series and they sound just as good. Now I will worry a lot less about my amp. Thanks again guys.
Old 12th May 2007, 03:53 PM   #8
Speakerholic
Cal Weldon's Avatar
Did you happen to notice if you lost a wee bit at the top end?
Old 12th May 2007, 04:03 PM   #9
I never thought of that before (haven't been putting tweeter in series)
how does that happen ? (losing the top end a bit)
Old 12th May 2007, 04:10 PM   #10
Speakerholic
Cal Weldon's Avatar
I was just thinking the extra inductance of two voice coils might filter it.
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
Dummy load for unknown output impedence ALustyGhost Instruments and Amps 4 2nd November 2008 10:23 PM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
M400 Impedence Thatch_Ear Solid State 1 18th November 2006 02:28 PM
speaker impedence inrank Multi-Way 5 12th May 2006 05:28 PM
Page generated in 0.09378 seconds (80.34% PHP - 19.66% MySQL) with 10 queries
