Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 20th January 2003, 12:25 PM   #1
Banned
Send a message via MSN to SkinnyBoy
Default The Project To End All Projects!!
TO PUT A FULL SIZE COMPUTER MOTHERBOARD, CD ROM AND HARDDRIVE IN A CD PLAYER CASE!!!
Seeing it is rather hot (~35 degrees everyday) this summer, I ripped apart the wooden box and am now TRYING to make it all fit in an old CDplayer case... hopefully in the future I can get an old burner to put in it so I can record CDs as well as play CDs, and MP3s, etc. For now I have the motherboard mounted, quite well actually. The CDrom fits.. JUST, but I am not too sure about the HD.. if you want pictures, just ask, I wil be more than willing.. Also, I intend to have a character LCD to the player will look (and function) very much like the original CD player.
I suppose the main reason why I doing this is to say when friends come around (There is a computer on my desk, if you can find it first go, you can have it.. )
THE OLD COMPUTER:
[IMG]
http://diyaudio.com/forums/attachmen...=&postid=94276[/IMG]
Old 20th January 2003, 12:27 PM   #2
halojoy is offline halojoy  Sweden
On Hiatus
So you will finally put an end to it?
Can I believe that?
wouldn't think so ....
Old 20th January 2003, 12:28 PM   #3
Banned
Can I believe that?
What can't you believe?
Old 20th January 2003, 01:51 PM   #4
Hanzwillem's Avatar
Default Re: The Project To End All Projects!!
something like this?
comp in cd-player
HW
Old 20th January 2003, 11:39 PM   #5
Banned
Default Re: Re: The Project To End All Projects!!
comp in cd-player
HW
Yes, like that except mine will still look like a CDplayer, and teh motherboard I am using is bigger, adn teh case I am using is smaller, and mine is therefor harder to do..
The one pictured doesn't even look like a CDplayer anymore... why didn't the person just make a new case from scratch? Woulda made mre sense to me. .
AND!!! I am using an external graphics card and sound card.. and my computer is only a P200..
Old 20th January 2003, 11:49 PM   #6
tiroth is offline tiroth  United States
I did this using the original CD player bezel for the CDROM. I used a MediaGX board with onboard sound and video. The biggest problem is doing everything without expansion cards--unless you get a 90 degree riser, and even then you are probably stuck with one.
Good luck!
PS Consider how LOUD the hardrive can be--even with no fans a computer can be loud.
Old 20th January 2003, 11:55 PM   #7
Banned
Good luck!
I was planning on using a riser card.. just gotta find one first.. and cheap... I know the computer is loud, but I don't mind.. If I use a laptop harddrive (which I may do) then this reduces the noise. Also, bigger fans are quieter but still move the same amount of air (is not more) when run at 7volts rather than 12, compaired to smaller fans.. 6cm = small 12cm = big..
Old 21st January 2003, 12:21 AM   #8
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
if you build one like the one above with no sheilding over the psu youll have more problems with the computer crashing and not working that you will have time to listen to it.
HEHE GOOD LUCK!
Old 21st January 2003, 01:52 AM   #9
Banned
I was going to use a DC-DC powersupply internally, and have the main powersupply externally.. Or I may have the whole powersupply external and feed it the +5 +12 -5 -12 and powergood through longer wires.. lol
Old 21st January 2003, 05:48 AM   #10
On Hiatus
Both ways could work well.
What do you think is the most practical way,
to attach your power?
/halo - thinks this is interesting
Run out of Projects Irakli Everything Else 2 12th December 2007 12:40 PM
One of my projects Brion55 Instruments and Amps 3 3rd July 2005 10:21 AM
8 Ohm projects?? bbksv Multi-Way 2 11th January 2004 01:13 AM
TB projects. RAW Multi-Way 8 4th January 2003 08:19 AM
Page generated in 0.12515 seconds (81.30% PHP - 18.70% MySQL) with 11 queries
