Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Ratio between wavelength and reflector size
Old 2nd May 2007, 08:10 PM   #1
kdw3 is offline kdw3  United Kingdom
Default Ratio between wavelength and reflector size
I've been trying to design an omni-directional sound source as part of my final year engineering project. Needless to say, it wasnt particularly effective.
The rig was set up like this. A 6" alpine speaker was hung from the roof in a spherical enclosure about 20cm off the floor. A reflector made of wood with the tip about 12cm from the speaker cone and the base on the floor. The base of the reflector is circular with diameter of 254mm and a height of 152. The shape was similar to parabola.
My question is this, the only two frequencies that were within the tolerancy were 4kHz and 8kHz. I believe that the main reason the other frequencies didnt work was because the reflector was either too big or too small. I have read a few articles on sound reflectors and they mention that the size of the reflector in relation to the wavelenth is important, but gives no mention as to what the ratio is.
I realise this is a difficult question, but any suggestions would be much appreciated
kdw3
Old 3rd May 2007, 03:14 AM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Have you played around with the java ripple simulator?
http://www.falstad.com/mathphysics.html
It might give you an intuitive grasp. You can draw reflectors, enclosures, etc... and see what effect they have on the wave propagation.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 4th May 2007, 01:39 AM   #3
MCPete is offline MCPete  United States
Default reflector sizing
For a given aperture of a reflector, sound of a wavelength greater than the aperture and projected towards the reflector isn't reflected and "sees" the reflector as an obstruction that it passes around. Conversely, where the wavelength of the sound is less than the aperture or roughly the width of the reflector, then the sound is reflected.
The above is an oversimplification as I think that the transition between reflecting and not reflecting is gradual. That is, if the wavelength of a sound projected toward the reflector is exactly equal to the aperture, then some sound is reflected and some passes around the reflector.
This should be applicable to what you are doing, but I have to say that I couldn't visualize your setup from your description.
-Hope that this is helpful.
Ratio between wavelength and reflector sizeHide this!Advertise here!
Compression ratio and diaphragm size in compression drivers inkasound Multi-Way 50 8th January 2009 04:38 PM
Prefered wavelength for UV exposure cosmox Everything Else 2 20th April 2004 03:06 PM
Positive Reinforcement When Driver Centers Are One Wavelength Apart At Crossover? kelticwizard Multi-Way 2 15th July 2002 05:48 AM
Copyright ©1999-2017 diyAudio
