Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th April 2007, 05:43 PM   #1
Default Pink Noise .wav generator
Hello. Does anyone know which software can generate pink noise .wav file.
I need to burn a cd with it.
Old 29th April 2007, 08:15 PM   #2
zapnspark's Avatar
Try this:
http://www.libinst.com/Long%20Pink%2...0recording.zip
Old 30th April 2007, 04:30 AM   #3
thank you much, i'll try to use it.
that track has some pulsing noise besides pink noise,
is this noise only for audio diffmaker or
would measurements still be correct if i use behringer rta?
behringer can generate it's own pink noise, but i can't use it, because
my car's cd player doesn't have audio in connectors.
Old 30th April 2007, 05:09 AM   #4
zapnspark's Avatar
It's called pseudo random pink noise.
It is mathematically generated and eventually repeats the same sequence over and over again.
Our brain has a knack for recognizing patterns and you are probably hearing that pattern in this particular WAV file.
(I hear a repeating "thump" in this WAV sample)
Just give this a try and see if it works for you.
There may be other pink noise WAV files on the WEB.
I just haven't searched for them.
Old 30th April 2007, 12:09 PM   #5
Pjotr's Avatar
There are many soft signal generators around on the web that generates pink noise for output through the soundcard. Most use the RND function built in Windows. These generate no patterns.
Simply record the .wav output through the Windows mixer into a file.
Old 30th April 2007, 03:49 PM   #6
Pjotr's Avatar
Have a look here:
http://www.nch.com.au/tonegen/
Saves to .wav directly as well.
Cheers
Old 30th April 2007, 03:59 PM   #7
scott wurcer's Avatar
You can make as long a sequence as you want with something like Audition, just FFT filter white noise at 3dB per octave.
Pain is never permanent
Old 30th April 2007, 04:00 PM   #8
ok thanks, i'll try them both, pseudo random and regular.
i used "audacity" to record pink noise generated by "truerta"
Old 30th April 2007, 06:06 PM   #9
Pjotr's Avatar
You can make pink noise right away with Adobe Audition. No need to use a dedicated filter.
Digged somewhat deeper into it to see what quality of noise it generaes. Here the flatness of the pink noise spectrum as generated by AA:
Old 30th April 2007, 06:08 PM   #10
Pjotr's Avatar
Here the spectrum of the NCH generator:
Does Pink noise follow the V x V/R method? OMNIFEX Solid State 18 5th January 2009 04:46 PM
What does pink noise sound like? jamikl Multi-Way 23 31st July 2008 03:23 AM
software 1/3 octave pink noise generator deandob Multi-Way 6 25th March 2006 07:05 AM
Pink Noise generator Lyra Analog Line Level 12 22nd March 2006 10:30 PM
Digital Pink Noise generator...? Lyra Digital Source 12 22nd March 2006 03:06 AM
Page generated in 0.12354 seconds (82.05% PHP - 17.95% MySQL) with 11 queries
