| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
im trying to install a new battery in a mp3 player and had a different capacity one on hand. can i use the same protection circuit for the higher capacity battery? im guessing that the higher capacity batery wont work with a lower capacity circuit? anyone know where i can find information on building your own lithium ion charging circuit?
#2 |
SparkFun Electronics has a $15 Li-Ion charger kit (well, assembled PCB) that gets power from either a wall wart or USB port on a computer.
I_F |
#3 |
Assuming the lithium-ion charging circuit detects when the voltage reaches a specified value (Wikipedia), the capacity change shouldn't matter.
What's the worst that could happen, a small fire?
#4 |
Li-ion batteries have almost the same charging profile as lead acid batteries: That is, constant current / constant voltage. But there is a big difference: They cannot stand overcharge. When the cell voltage becomes higher than 4.2 V the electrolyte will be destroyed permanently rendering the battery useless then. Therefore they need a battery management system (BMS) when more cells are in series to watch each cell. So no one will be overcharged. Putting a new single cell battery in with a just higher capacity means only charging will take a little longer. Provided the current charger is in good working order. Here is some good reading: http://www.batteryuniversity.com/ Cheers |
| Charging Lithium ion batteries | Diy_Ambitious | Power Supplies | 8 | 10th November 2009 01:30 PM |
| Fun with Lithium Ion | EWorkshop1708 | Power Supplies | 20 | 26th May 2009 01:57 PM |
| Battery Charger for 15V Li-ION Battery Pack ??? | Jan Dupont | Parts | 2 | 11th April 2009 02:18 PM |
| Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 | tyler477 | Solid State | 1 | 31st October 2008 04:24 AM |
| Digital camera not liking Lithium ion battery | xplod1236 | Parts | 5 | 21st December 2007 12:17 AM |
| Page generated in 0.08840 seconds (62.88% PHP - 37.12% MySQL) with 10 queries |
