| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi !!
How do I apply the common ground layout on eagle? I mean, I need to fill the unused pcb areas with cooper, and then I can connect it to the ground. I already searched here in the forum, but I couldn't find it Best Regards ! |
#2 |
Click the polygon button, enter the name of you ground signal (eg. GND, AGND or something else) and draw the polygon.
/U. |
#3 |
Exactly! Connect de polygon to exactly the same net name as to what you want you want it to be connected in the polygon set up panel (in this case the gound). Same with Ultiboard and Protel. B.t.w. I am working with Protel. Does anyone know how to set up different clearances for different polygons in Protel? It appears that there is only one clearance setting for all polygons. Cheers |
#4 |
Do you mean clearance between different polygons, or clearance around a certain track cutting through a polygon?
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#5 |
It is for drawing around traces and pads.
I am giving Protel a test drive at the moment and working for week now with it at a serious board. Also found a way to ad vertices to polygons when editing them but there appears to be no way to remove vertices |
#6 |
Thank you veeeeeeery much !!! It worked !
And I also have problem with the BUS. I can draw it, but I can't connect it with the wires... My screen is a mess of wires because I can't use the bus Best Regards !! |
#7 |
Nando, do you mean you are seeing lots of little yellow lines?
If so, you need to use the routing tool to change them to traces... it is the redish line icon just above the / anf T icons... use the tool next to it to "erase" errors (change them back to yellow lines... when you have a component more or less where it should go, click the ratsnest icon... it will reroute the yellow traces to the closest points matching your schematic....makeing it easier to route them.... |
#8 |
diyAudio Moderator Emeritus
He means he wants to use a bus in the schematic editor but can't for some reason. As a result he has connection wires all over the place.
nando, you should be able to place a bus and connect nets to it. Don't try to connect wires to it use the nets tool for connections.
Brian |
#9 |
Hi !
Nordic, please take a look at the picture, and you'll see what I meant with bus. Also, I have four VDD Pins, I want to bypass them with 100nF caps, and the caps must be place near the pins. I did this on the schematic, but eagle made very different on the board, it tied all VDDs and then it connected the VDDs to the caps paraleled http://img362.imageshack.us/img362/9823/eaglekg5.png http://img50.imageshack.us/img50/4858/eagle2cc5.png Thank you very much! Best Regards |
#10 |
>>I have four VDD Pins, I want to bypass them with 100nF caps, and the caps must be place >>near the pins. I did this on the schematic, but eagle made very different on the board, it tied >>all VDDs and then it connected the VDDs to the caps paraleled .
If you rearrange the caps the way you want them to be placed and then click the "ratsnest-tool" then Eagle should redraw the connections between the parts and let you route the traces the way you want. /U. |
| Eagle vs. Sprint-Layout for PCB design/layout | hollowman | Parts | 9 | 9th July 2011 04:34 AM |
| common ground or not? | Mordor | Car Audio | 5 | 7th October 2008 12:08 PM |
| A common ground between preamp and amp | marthaman | Solid State | 4 | 3rd November 2007 09:00 PM |
| Common Ground Layout & Manual Work ! | -_nando-_ | Chip Amps | 3 | 5th June 2006 08:43 PM |
| Adcom...common ground amp?? | Heiney9 | Solid State | 59 | 25th October 2005 02:06 PM |
| Page generated in 0.10645 seconds (79.47% PHP - 20.53% MySQL) with 10 queries |
