Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 13th February 2007, 06:45 PM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Smile Zelscope for $20 - Windows software scope!
Download a 14-day evaluation version of Zelscope here (720 kB)
(right-click the link then select "Save Target As...")
By installing the evaluation version, you acknowlegde the terms of the License Agreement.
Pricing:
Single user US$ 20
What Zelscope software oscilloscope, for Windows does,
is use your existing PC soundcard = input of audio signals
Then you use this program as an Oscilloscope.
This is a low cost & very simple solution.
I have installed the 14-days version.
Some thoughts, What is needed, as I can understand:
1. use a test-CD
2. a cable from amplifier output to soundcard input
3. if testing amplifier at Very high Output voltages, you may need some attenuator
to adjust not to get TOO High input level for your soundcard
Website,
with free download of this program (fully functional but 14 days limit)
http://www.zelscope.com/
See my attachment for SCREENSHOT from my install
lineup
lineup
Old 16th February 2007, 01:29 PM   #2
lineup's Avatar
hi
At first some facts:
1. I used a test-CD with special test signals.
I have no doubt signals are of good quality.
2. I used my Technics Cd-player. It has got 24bit-resampling.
I set Re-Sample to ON.
3. I have Sound Blaster 24-bit Live! soundcard.
It is a medium quality rather low price card.
As can be seen in attachment,
400 Hertz square wave is not too bad.
But not perfect.
The quality when using this www.zelscope.com Software Oscilloscope
is of course dependent on the quality of your Sound Card.
Especially when dealing with square waves.
They may be difficult for a CD recorded with 44.100 kHz.
lineup
lineup
Old 16th February 2007, 01:33 PM   #3
lineup's Avatar
Here is an attachment of the Screen Capture of zelscope windows
and all the Scope 2 Channel settings options.
The first picture in post above was saved by using the built in
'Copy scope monitor screen to Clipboard'.
You can also 'Save directly as a .BMP image'.
lineup
lineup
Old 17th February 2007, 02:38 PM   #4
cpemma is offline cpemma  United Kingdom
This might interest you for higher frequencies (I've not tried it). Uses PP.
Old 17th February 2007, 02:58 PM   #5
lineup's Avatar
Yes, look good.
As can be seen, Uses this Parallel port circuit
with National 8-bit Analog to Digital Converter. http://www.national.com/pf/AD/ADC0820.html
And the free downloadable software makes an Oscilloscope of this.
There are also some links to other PC Oscilloscopes.
http://www.geocities.com/lptscope/
lineup
Old 17th February 2007, 03:27 PM   #6
neutron7's Avatar
44.1 khz sampling rate is not great. say you have a 10khz waveform. then you will have sometimes 3 sometimes 4 points to describe the entire wave. you will not be able to see crossover distortion, overshoot or any other details of the wave.
the peaks of the waves may not fall in place of the sampling points so you could not even measure amplitude very well.
i would go with the hardware. except it uses the priinter port. maybe a USB2 scope would be a cool project.
Old 17th February 2007, 03:46 PM   #7
lineup's Avatar
right.
1. The source of signal into Amplifier.
Better use my Function Generator.
CD (16bit 44.1kHz ) signals are limited. Especially for squarewave testings.
2. PC Soundcard should have as high resultion and sample freq as you can afford.
My Sound Blaster Live 24-bit is told to have 24 bit / 96 kHz sampling.
Of course would not hurt to upgrade to 24/192
3. www.Zelscope.com is a good working software.
It is also possible to do a Fourier FFT Spectrum analysis.
There are for sure other much more advanced PC Oscilloscope softwares out there.
But maybe not that many for $20 dollars.
PS. I found a crack .... so I have it now for NOTHING. DS.
I will hook up my Function Generator
and let the scope look at some square waves = 1 kHz standard
Will be interesting to compare to 400 hertz square wave from my test CD ( see image in post above ).
And this will show what PC-Card + Zelscope can really do.
Without CD 44.1 kHz limitation
Regards, lineup
lineup
Old 17th February 2007, 04:16 PM   #8
neutron7's Avatar
on their site it mentions 44.1 khz support but will it actually support higher bitrate and sample depth?
Old 19th February 2007, 11:03 AM   #9
awpagan is offline awpagan  Australia
any analogue signal into a pc will have "pc" noise on it and needs compensation before converting to digital, but the idea works well for a cheap solution.
I used the trueaudio software a long time ago.
the free version of trueaudio is still very capable
http://www.trueaudio.com/rta_abt1.htm
I would prefer the usb way, if i could afford it.
http://www.bitscope.com/software/
allan
Indecision makes the world gone round.
Maybe
Old 22nd February 2007, 02:50 PM   #10
lineup's Avatar
hello
Here is a Fourier analys
of a 1 kHz sinus 1.0 Volt,
generated by my fucntion generator
Using Zelscope Oscillope.
Picture was exported using the built 'Export as .BMP'
Then I made it smaller and converted.
lineup
SoundEasy (& other windows audio software) via VMWare Fusion? hifiZen Everything Else 12 28th November 2008 08:04 PM
Windows software for schematics and PCB akis Parts 11 5th August 2008 07:12 AM
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 09:59 PM
A Software To Draw Blueprints Using Windows 98 OMNIFEX Multi-Way 1 10th August 2004 04:12 AM
Page generated in 0.12948 seconds (80.70% PHP - 19.30% MySQL) with 11 queries
