Modifying a tube tester into a curve tracer (oscilloscope X/Y outputs) ? - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 19th October 2006, 06:31 PM   #1
bembel is offline bembel  Europe
bembel's Avatar
Send a message via Yahoo to bembel
Default Modifying a tube tester into a curve tracer (oscilloscope X/Y outputs) ?
Hi all,
I'm looking for a simple/cheap way to plot tube curves, and have a spare hickock I177b transconductance meter sleeping there.
(here a link to the schematic ----> http://www.suertenich.com/html/tester/i177.gif )
I also own the expansion box MX949 that allows any pins connection
My basic idea is to apply a stairsteep signal to the grid, while a rectified AC is sent to the plate ( also used as X deviation )
Y would come from a sense resistor.
It would also be nice for a future project to reuse those outputs to feed a computer interface.
Any Suggestions ?
Plus je pédale moins vite, moins j'avance plus vite !
Old 20th October 2006, 09:02 AM   #2
coresta is offline coresta  France
coresta's Avatar
Bonjour, le principal pb est de trouver un générateur de tension en escalier . Le schéma du tektro 570 se trouve et donne une idée de la complexité du système . J'y réfléchis également !
Old 20th October 2006, 09:16 AM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
coresta, pertinent though your comment is, please remember that this forum is designated as English-speaking.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 20th October 2006, 09:21 AM   #4
coresta's Avatar
Ok Mr EC8010 Just told i was working on the same idea as i discovered that the main difficult of the Tek 570 was the tubed steps voltage generator
Old 20th October 2006, 09:33 AM   #5
EC8010's Avatar
Sadly, curve tracers are difficult. Often, you see equipment that is overly complex, but getting the complexity of a curve tracer down to manageable is difficult. Every time I look at the idea, I turn away...
Old 20th October 2006, 12:27 PM   #6
bembel's Avatar
Hi, my first attemps are very impressive !
Topology allready works (tested with low voltage ECC86), not used yet the tester but two DC supplies (logic for stairstep + filaments) and an AF generator (AC sweep).
The curve is clear and very instructive (you can see them moving as filament voltage change for example).
Here's my test sample schematic:
(thanks to Kazuhiro Sunamura (---> http://www.intio.or.jp/jf10zl/) for the idea !)
PS: the spice schematic shows a transistor being tested at the right, I've breadboard it and tested it with both transistors and tubes (ECC86 & ECC83) AF gen feeding a step up transformer for VA >50V, stairstep fed to the grid via a tel line transformer (can provide different bias offsets for the stairs.)
Old 20th October 2006, 12:40 PM   #7
Yvesm is offline Yvesm  France
Yvesm's Avatar
Hi French and British guys
Same work pending !
For now a very dumb plate voltage and stairstep generator:
To be improved a lot, indeed
As is, it allowed me to write an application in VB which can do that:
Just using a sound board as an A to D
Yves.
Old 20th October 2006, 12:45 PM   #8
jackinnj's Avatar
Actually, once you figure out the retrace blanking it isn't that difficult to implement with a scope -- the second issue of Glass Audio had such a circuit in which grid voltage was stepped with a CMOS clock.
There are, however, any number of data acquisition cards which allow you to both control voltages and measure VI -- and dump the data into excel for analysis -- the beauty of employing one of these, even with an inexpensive tube-tester (like an Eico or Heathkit) is that all the nasty wiring is already done. once the data is in excel all the useful information can be calculated -- and you can compare multiple devices for matching.
with regard to a "Sound Card" -- better make sure you put some protection on the output or you will quickly fry the caps -- and sound cards don't take well to DC inputs anyway -- if you can get a copy of the July 2006 Dr. George Steber had an article in the ham radio magazine QST describing a sound-card based IV tracer. A local ham radio club in France should have a copy.
jack
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 20th October 2006, 12:49 PM   #9
Yvesm's Avatar
And thanks to you for pointing at (Great link !)
Yves.
Old 20th October 2006, 01:04 PM   #10
SY's Avatar
Jack, the soundcard doesn't need to see DC. A good workaround is to apply an offset sinewave with a moderate frequency (say, 500 Hz) to the plate, with the troughs reaching some low voltage or zero and the peaks reaching the max voltage of interest. This can be done with a simple HV amplifier driven by the soundcard.
At the same time, apply a 510 Hz offset sinewave (running from zero volts to cutoff) to the grids.
Using the soundcard input, measure the AC current through the plate/cathode via a small sensing resistor.
If you are generating these waveforms via software, then all the timings are known and a complete set of tube curves can be constructed in about 0.1 second. Running a full second allows averaging for lower noise.
I'm rather software stupid, so this has sat in a drawer for about forever without getting done.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
DIY tube testing Curve Tracer whitelabrat Tubes / Valves 5 24th October 2007 09:11 PM
Tube curve tracer project andrei Equipment & Tools 17 18th August 2007 12:49 PM
Anyone got a tube curve tracer for sale? jazzyjoepass Swap Meet 0 26th August 2004 05:24 AM
FS: all tube transistor curve tracer SQ Kid Swap Meet 1 4th July 2004 11:10 PM
Copyright ©1999-2017 diyAudio
