About TEK 7000 series scopes - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 10th August 2006, 02:22 AM   #11
The tube scopes...5XX series that had interchangable verticle modules had several modules available that could read down in the uv region.... I think one would have to put at least two 7A26's which are good down to 5 mv in series to be able to do that.
The 1A1 had a sensitivity of 500uv and there are also differential input modules with similar sensitivities.
Mark
KSA-100 WIKI
Old 10th August 2006, 12:21 PM   #12
jackinnj's Avatar
the differential amplifiers for the 7000 and 5000 series scopes will get down to 10uV/division -- and you can bandpass limit the response.
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 17th August 2006, 03:16 PM   #13
I believe that the TEK 1A7 differential will do exactly the same thing. Of course on HAS to have a screen room or be well underground in order to read anything accurately at that low of level.
I picked up a nice-mint 564B Storage Scope yesterday for 40 bucks. In like new condition it is an ex-BYU Physics scope so probably does not have tons of hours on it as an industrial lab scope normally would. All tubes test good and it works perfectly. Sure, its only 15mhz but its dual flood gun type storage crt has a trace as sharp as a regular scope does... much sharper than my 7633 mesh type storage scope has.
I have alot(over 20) of both TEK solid state and tube scopes and the tube scopes are still the better performing of the lot.
Mark
KSA-100 WIKI
Old 17th August 2006, 03:48 PM   #14
jackinnj's Avatar
if you note the Linear Technology website application notes -- Jim Williams uses a TEK tube scope for his noise measurements.
I went to rent the Faraday-Shielded room at my alma mater in NYC -- regrettably they had taken it apart. I now have a setup with brass screens retrieved from the dumpster. I think that when you see an amplifier with THD approaching 0.0004%, or the noise measurements in the pico-volts they have made the measurement in a shielded environment.
Old 17th August 2006, 09:43 PM   #15
poobah is offline poobah  United States
poobah's Avatar
OK,
I see that one of the vert amps for the 7000 uses powered probes. Anybody know about this?
Old 19th August 2006, 05:29 PM   #16
He is most likely using the 1A7 diifferential amp to do this since it has the lowest noise floor of all the tube based plig ins. I am in the process of cleaning one up (Ultrasonically) that I just bought on E-Bay. I also picked up a 1L20 Spectrum analyzer but have not received it as of yet... this is a VERY rare TEK piece!
Mark
KSA-100 WIKI
Old 2nd September 2006, 12:59 AM   #17
I received my 1L20 spectrum analyzer plug-in the other day. This is a really neat piece and a very rare one at that.
KSA-100 WIKI
Old 2nd September 2006, 01:01 AM   #18
Left hand view.....Lots of plumbing!
KSA-100 WIKI
Old 2nd September 2006, 01:03 AM   #19
Right hand view....
KSA-100 WIKI
New scopes apassgear Parts 0 26th November 2008 10:20 PM
Tektronix 7000 or 11000 series or ..? Speedman Parts 15 7th July 2008 01:40 PM
Scopes Onvinyl Equipment & Tools 0 28th September 2006 05:41 PM
Scopes´ TroelsM Parts 0 16th June 2006 06:50 AM
New TEK Scopes Bryan Tubes / Valves 22 25th November 2005 12:56 PM
Copyright ©1999-2017 diyAudio
