diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Equipment & Tools (http://www.diyaudio.com/forums/equipment-tools/)
-   -   Lab Power Supply Current Limiting Q (http://www.diyaudio.com/forums/equipment-tools/64688-lab-power-supply-current-limiting-q.html)
Wynand 21st September 2005 01:10 PM
I'm currently designing a Lab Power Supply to use for various Audio Projects.
I'm using a PC Power supply for 5 12 -5 -12 Volts for a beginning but I want the +and- 0-35v Supply to be the heart of it.
I've decided to use the LM338 T0-3 as my positive voltage regulator.
It'll also be used for the current limiting (5A should be enough limiting?)
My problem is.... do I need a current limiting circuit on the negative supply line aswell or does all the current come from the positive side(what happens at GND in respect to -V)
Wynand 21st September 2005 01:21 PM
2 Attachment(s)
Heres a pic to show what I dont understand
ctardi 22nd September 2005 03:08 AM
Don't quote me on this, but i think it will work with only + Limited.
Nordic 23rd September 2005 06:27 PM
Wynand if you do manage to pull it off gimme a shout....
I'd be interested in the setup.... have a few PSU's I can pilage for parts...
TwoSpoons 27th September 2005 10:44 PM
You DO need your current limit in both + and - supply. It is quite possible to pull current from GND to V- without any current from V+.
Proof:
Connect light bulb from GND to V-. Does it glow? Of course it does!
Copyright 1999-2017 diyAudio
