tube tester - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 5th April 2005, 01:47 PM   #11
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
All you really need to test an EL84 is a 300V HT supply, a heater supply, and a few components. Connect the +300V to the anode and screen grid (add a 100 Ohm 1/2W resistor in the path of the screen grid to prevent oscillation. Connect the cathode and g3 to 0V via a 270 Ohm 1W resistor. Connect the grid to 0V via a 10k resistor. Apply heater power and you should see about 11V on the cathode - indicating 41mA of current.
Shorts: The most dangerous short is between grid and cathode. But it may not show up hot. You could use a meter on its resistance range to test with heater power applied, but I wouldn't bother. I'd just pop it in the test circuit and switch off the 300V if there's a firework display in the valve or if the voltage across the 270 Ohm resistor rises beyond 15V.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 5th April 2005, 02:23 PM   #12
powertriode's Avatar
Has anyone here built the Steve Bench Tester?
Tube Tester's Space1 Equipment & Tools 17 2nd June 2009 08:54 PM
DIY My tube tester sjh327 Equipment & Tools 0 30th November 2008 02:25 PM
Tube Tester jtwrace Equipment & Tools 5 8th September 2007 04:47 PM
Tube tester Sjef Equipment & Tools 6 29th January 2007 08:38 PM
help using Tube Tester ebarker2 Equipment & Tools 3 31st January 2004 02:30 AM
Copyright 1999-2017 diyAudio
