Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 10th June 2002, 08:16 PM   #1
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Useful tools and techniques
I wanted to start a thread where anybody could say something about favourite and useful tools they use as well as some helpful methods for doing things easier and saving time and money. I think it might be beneficial for all.
I know that I might not be breaking any new ground here, but probably not everybody is familiar with that tool, and I use it always when soldering. I can't imagine working without it and it is especially helpful when I need both hands and can hold that thing with my mouth. It is called Solder Dispenser and I got mine from http://www.percyaudio.com/ for $10.
Old 10th June 2002, 08:38 PM   #2
tvi is offline tvi  Australia
tvi's Avatar
I have been considering getting something like this
<a href="http://www.garrettwade.com/jump.jsp?lGen=detail&itemID=105318&itemType=PRODUC T&iMainCat=10055&iSubCat=10059&iProductID=105318"> <img src="http://www.garrettwade.com/images//product/family/91G0105.jpg" ></a>
unfortunately the versions I have seen locally don't look that well made.
Might be useful when things are to big for a drill press , or if you don't have room for the drill press.
James
Old 10th June 2002, 09:38 PM   #3
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Peter,
speaking of soldier dispensers, what kind of soldier do you prefer to use?
Brian
Old 10th June 2002, 10:10 PM   #4
I'm using Cardas solder because I got it really cheap. In less critical applications I'm using 2% silver. I never did listening comparisons as to the sound of differend type of solder. Check the following link: http://www.diyaudio.com/forums/showt...4970#post34970 (page 2). The guy who calls himself Scorpion and everybody thought was a rookie explained the sound of different types of solder better than anybody else on that forum.
What I also like to use when soldering is a no clean rosin flux. Sometimes when soldering big wires or binding posts the joint doesn't always look nice and shiny. I'm using small brush and wett that joint with liquid rosin flux and then heat it again. It always look perfect after that.
Old 10th June 2002, 11:30 PM   #5
fcel is offline fcel  United States
Default Steel Wool
What about what kind of material do you guys use to wipe off the sometime dirty solder from the tip of the soldering iron? I have seen people use those steel wool for cleaning cooking utensils. I think they are pretty good and it cost only 25cts.
Old 10th June 2002, 11:32 PM   #6
You can get special sponge for that purpose and when you wet it with water it works better than wool when using small tip.
Old 10th June 2002, 11:47 PM   #7
seangoesbonk's Avatar
Default Re: Steel Wool
NEVER USE STEEL WOOL!!!
soldering iron tips are usually plated. (i think weller tips are iron plated copper) It you use steel wool to clean the tip, you will eventually remove the iron, leaving the copper exposed. the copper will oxide and the tip will be ruined.
using a wet sponge on a hot iron is the better way to clean the tip.
My girlfriend's sub is bigger than mine...
Old 11th June 2002, 12:08 AM   #8
Actaully the copper shouldn't oxide because it would always be covered with solder which will protect against oxidization. The tip might wear off though.
Old 11th June 2002, 12:08 AM   #9
When you guys said wet sponge, do you mean the regular sponge that we normally use in the kitchen/bathroom? If not, part number & vendor name please. Thanks.
Old 11th June 2002, 12:14 AM   #10
EB1003. You should get yourself Digi-Key catalog. It's the fastest way to find out about something.
Crossover construction techniques wiredmonkey Multi-Way 13 25th April 2009 04:27 AM
Woodworking techniques johngalt47 Multi-Way 33 11th March 2009 08:07 AM
Transistor biasing techniques keantoken Solid State 22 21st September 2006 06:13 PM
Techniques SL-230 rewire justn Analogue Source 5 1st October 2005 07:36 AM
Page generated in 0.89668 seconds (10.73% PHP - 89.27% MySQL) with 11 queries
