| Equipment & Tools From test equipment to hand tools |
#71 |
That what it takes to drill properly aligned 4 holes.
The work on a CD transport continues.
#72 |
Peter Daniel?
whatsup with Hpotter? Is Peter Daniel your real name or another hero?
Pedro Oliveira |
#73 |
You should be reading introduction section more often.
This one's for real.HPotter is leaving the stage. |
#74 |
Some people were complaining about countless screws they had to put in when building their amps.
Today I decided to use some of my aircraft tools and try riveting. Clecos were used to hold the parts together while drilling. After holes were open with size 40 drill bit and then size 30, I countersunk the holes for flush head rivets with piloted countersink.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#75 |
After deburring the holes I used a squeeze gun to install the rivets. It was actually the first time that I tried that technique at home, but I must say that I like the results and I will do it more often
For anybody interested in obtaining some of the tools I used here, http://www.yardstore.com/ offers good selection and prices on used aircraft tools an accessories.
#76 |
I neal before god!
what will be next Peter Daniel? home made drop forged aluminium heatsinks?
Pedro Oliveira |
#77 |
I'm thinking about building a small aeroplane in my backyard...
#78 |
like 747?
but with better parts (at least the audio will be great!
Pedro Oliveira |
#79 |
I hate to be a threadjacker, but this is in the same genre...
I'm in the process of making an amp based around ESP P88 preamp and 2 ESP P3A amp boards (passive bi-amp - I would go active but I don't want to kill my lovely B&W 603-S3's). Anyway the question I had was where to find good heatsinks and cases (pre-made - I don't have time to make) for the amp in the UK? The sinks need to be about 1deg C/Watt Also any ideas about cases with heatsinks available in the UK - I was thinking of buying a Maplin (UK electronics distributor) rackmount case and using heatsinks internally, but if anyone can suggest a good distibutor of cases with combined sinks in the UK that would be great. Also I don't want to spend the earth (I am a student). |
#80 | |
That has to be the ultimate DIY feat! The kits are like the ones you may have made as a child - you get a series of flat packs of plywood and literaly just glue them together and source and engine! Crazy huh |
| Crossover construction techniques | wiredmonkey | Multi-Way | 13 | 25th April 2009 04:27 AM |
| Woodworking techniques | johngalt47 | Multi-Way | 33 | 11th March 2009 08:07 AM |
| Transistor biasing techniques | keantoken | Solid State | 22 | 21st September 2006 06:13 PM |
| Techniques SL-230 rewire | justn | Analogue Source | 5 | 1st October 2005 07:36 AM |
| Page generated in 0.12268 seconds (75.14% PHP - 24.86% MySQL) with 11 queries |
