New from Gorilla Glue -- Clear! - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 17th April 2017, 06:51 PM   #1
jackinnj's Avatar
Default New from Gorilla Glue -- Clear!
I saw an ad for it, but hasn't shown up locally so I ordered via Amazon. One of the non-porous surfaces to be joined must be moistened:
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 17th April 2017, 07:45 PM   #2
grimberg's Avatar
In 2006 I had to rebuild one of the gates which gives access to the backyard. At the time I bought into the Gorilla Glue b.s. (or should it be ape s.?) and used it to assemble the gate frame. In 2008 I rebuilt the other gate using water-resistant Titebond. In 2012 the glued joints of the first gate started to come apart, so I built a new frame using water-resistant Titebond.
I have heard similar stories about Gorilla Glue failure but somebody also tries to blame it on user error. Whatever the reason is, the second gate will turn 9 years old in June and is still holding strong. I will never again use any of those monkey products, and I share my bad experience with anyone who will listen. Use it at your own risk!
Old 18th April 2017, 02:55 PM   #3
jackinnj's Avatar
Titebond i believe, is mostly wood-working products. I am testing the product for electronics. It's thick and gap-filling.
Old 18th April 2017, 03:00 PM   #4
grimberg's Avatar
You did not mention that in your first post. What are you trying to glue together?
Old 18th April 2017, 03:05 PM   #5
Pano is online now Pano  United States
Pano's Avatar
Please let us know how it goes, how it handles and sticks.
I recently found the only CA glue that has ever worked for me. Krazy glue Max Bond gel. It actually works. Gorilla sells a CA glue that is clear and in a bottle like you picture, but your glue seems to be something new.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 5th May 2017, 06:27 PM   #6
jackinnj's Avatar
It really does dry clear. I would say that it is a bit more elastic than I had anticipated, less so than RTV.
Using it to "adhere" a pair of meters onto my "Engineer's Amplifier".
Old 5th May 2017, 07:05 PM   #7
cbdb is online now cbdb  Canada
If the same as there yellow glue it expands and hardens into a hard foam. Don't think it's what you want. Gorilla also makes a clear crazy glue that dosnt expand. Might be a better option. I know it sticks, my wife spilled a little on a counter top and its still there a year later.
Old 5th May 2017, 11:09 PM   #8
jackinnj's Avatar
The volume seems to be the same a few weeks later, did not "foam".
Old 6th May 2017, 12:12 AM   #9
PRR is offline PRR  United States
PRR's Avatar
BTW FWIW: Liquid Nails now comes in clear.
Have not tried it. The tan-ugly stuff has been pretty useful for odd joints which will not show. It comes toothpaste-size now, not just caulk-gun cartridges.
Old 6th May 2017, 12:43 AM   #10
Pano's Avatar
Thanks for the update. I've looked at this and the Gorilla super glue. Would be interesting to use these.
Gorilla GRLA 3000/1D has no sound. activik Car Audio 40 11th September 2016 05:35 PM
Gorilla GRLA 3000/1D help Kleinteich2 Car Audio 7 29th January 2014 12:10 PM
Hate Waiting for Gorilla Glue? Patrick Bateman Subwoofers 5 2nd September 2013 03:33 PM
MDF and Gorilla Glue Consul Multi-Way 23 26th May 2007 01:14 AM
I foumd this amplifier in the net, called Gorilla destroyer X Solid State 11 21st February 2006 03:08 PM
Copyright 1999-2017 diyAudio
