Zener diode tester - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 4th May 2016, 01:59 PM   #1
Default Zener diode tester
Hello all. I have a lot of zener diodes which is difficult to read their values from. From small to big metal ones. I want to build a zener tester. Would this be a good circuit ? It can test up to 50v and trigger between 5 and 15ma.
Jan
Old 4th May 2016, 02:09 PM   #2
Mooly's Avatar
It looks fine. C1 might be a little to small, even for your small currents. The LM317AHV (that's the high voltage version) has a minimum output current (in voltage mode) of around 15 ma worst case I think. I'm not sure how that relates to using it in current source mode.
There is also the TL783 High-voltage Adjustable Regulator which is functionally very similar but can withstand 125 volts differential.
Old 4th May 2016, 02:19 PM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
I don't like the idea of relying on a 317 for current regulation: when you connect a zener, there will be a current spike, because the regulation loop is slow.
At the very least, you should include a series resistor (a few 100's ohm) to avoid frying or damaging zeners, but using just a transistor CCS looks like a much better option: you do not need a very high static accuracy for this kind of tester; a series resistor (a few 10's of ohm) would still be a good idea though.
Here is a tester I made that goes to 200V, but with a fixed 1mA test current:
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 4th May 2016, 02:46 PM   #4
Thanks for the feedback guy's. Elvee you mean to put the resistor in series with the zener under test to lower the current for lower power zeners I presume.
Will a 100V Vceo NPN transistor do ? Or something like a MPSA42. I see the origional is a 400V transistor .
Jan
Old 4th May 2016, 03:52 PM   #5
Frex is offline Frex  France
Hello,
If you have an oscilloscope, you can easily plot the I=f(V) of the zener using
the X/Y mode and driving the zener with a AC secondary of transformer and
a series resistor + shunt resistor.
You can look here for example.
Frex
Old 4th May 2016, 05:09 PM   #6
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
SLOW???????
Where do you see a time constant?
LM317 rules what current passes there and it's only reading voltage drop across a small value resistor.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 4th May 2016, 05:45 PM   #7
Elvee's Avatar
Originally Posted by JMFahey View Post
SLOW???????
Like any regulator, it has an internal loop compensation.
In the absence of a zener, it tries to force the maximum output to comply with the regulation/closed loop condition, but since it is impossible, it is saturated and when a load appears, it has to first come out of saturation and then to integrate until it actually regulates.
There is thus a short current spike at the output.
Like this, but the CCS is a better option:
Old 4th May 2016, 06:56 PM   #8
Thanks all !!
Jan
Old 4th May 2016, 07:07 PM   #9
Elvee's Avatar
The "simple" CCS also has the advantage that you'll be able to test up to 75V zeners (avalanche in fact) with an 80V supply (and even more if your primary supply is higher)
Old 4th May 2016, 07:45 PM   #10
Elvee's Avatar
I forgot to put a limiting resistor on the transistor CCS: as soon as there is more than one transistor involved in the loop, it is a wise precaution; for a more complex (and slower) system like a complete VR, it is more than just a precaution: the sim shows the behavior of such a reg when the load is brutally switched from zero to infinity.
Don't trust the fine details, it is just a sim, and the regulator modeled is not a HV (hence the 30V supply) and is a lower current, M-version.
The reality could be better or worse, but the general outlook is correct.
Mosfet with inverted parallel diode or zener diode nonprof Car Audio 4 23rd October 2015 03:18 AM
zener diode watts ian33 Car Audio 6 11th June 2012 02:13 AM
Zener Diode Help joesch1999 Class D 2 3rd January 2011 05:35 AM
Zener diode indentification! bbakota2000 Parts 2 22nd March 2004 11:55 PM
W054 Zener diode, what is it? Andypairo Parts 5 25th December 2003 04:31 PM
Copyright ©1999-2017 diyAudio
