QnDhfe - the Quick & Dirty transitor Hfe tester - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 30th January 2016, 09:47 AM   #1
nnx is offline nnx
Default QnDhfe - the Quick & Dirty transitor Hfe tester
Hello,
In search for an ultra-simple hfe-meter I found this on the EEVblog:
How come transistor beta hFE test is only on cheap DMMs? - Page 1
After simulating in spice and adjusting the resistor values a bit, I decided to give it a go - dead pcb style. Materials are a 3V battery w/holder, 5 resistors, one 8-pin ic-socket and some random piece of leftover board. It seems to work but accuracy is no good, but it makes it possible to select and match transistors.
Please enjoy
nnx
Old 30th January 2016, 10:05 AM   #2
JonSnell Electronic's Avatar
Q2 is drawn wrong, upside down!
Answer to your question is because if you purchase a quality DVM, one requires all the cost to be for a DVM. One can purchase a transistor tester separately and very cheaply.
Support for Fender, Marshall and all Valve Equipment including Audio Innovations, Quad and Leak. www.jonsnell.co.uk
Old 30th January 2016, 10:26 AM   #3
nnx is offline nnx
Default Corrected!
Thank you for the comment! Q2 was upside down, but has now been rotated in the schematics. The output from the tester is in millivolts, one mV approximates one "degree" of hfe.
Of course it would be better with a proper dvm with built-in tester, or a dedicated transistor tester. But this is just a little fun project.....
Old 30th January 2016, 12:21 PM   #4
And very useful too.
Old 30th January 2016, 03:30 PM   #5
PedroDaGr8's Avatar
There is also the safety aspect. A transistor tester on a DMM pretty much always exposes the voltages on the inputs on the transistor tester pins as well. This is both a risk for arc over a well as shock/electrocution of someone who might have their hands near the pins. Combine this with the fact that the transistor tester in these devices gives you a very relative value and it just becomes too many negatives to include in a quality meter.
High quality HFE Tester- VC294 or DY294 ? umut1001 Equipment & Tools 1 1st September 2014 04:11 PM
Electret Mic, Quick & Dirty for PC tommy_o Parts 2 22nd June 2010 02:22 AM
Quick And Dirty ~75W Guitar Amp sorenj07 Instruments and Amps 7 4th June 2007 11:00 PM
Quick and Dirty X-over bjackson Solid State 1 16th August 2005 06:32 AM
How do a quick & dirty non os in a CD650 Bernhard Digital Source 17 7th April 2004 07:18 PM
Copyright 1999-2017 diyAudio
