DIY Audio Analyzer with AK5397/AK5394A and AK4490
I suggest we (the "RTX Community") should use MATAA and develop some more functions which are more tailored to electrical measurements since the current SW is more focused on acoustic environments at the moment.
The Input/Output-Range-Control could also be implemented in MATAA, if the API is available.
@JensH: Any update on the programming API? Thanks!
Oh, wow, well thanks for the heads up for MATAA! However, I am totally against "we should all use the same software". Also, MATAA was certainly not made with user friendliness in mind, and I don't think Matlab/Octave is for everyone. But yeah, I prefer MATAA over everything else ;-)
I just updated Win 10 to the creator update to see if the new USB UAC 2 driver worked. It doesn't at this time. . .
I did a set of RMAA loopback tests at 192-24. The levels are all very close to clipping so not the best possible performance. I generated an HTML report but don't know how to share it here.
The 60 Hz noise is lower in the +20 dB in/out. Its really low in any case.
Here is a summary at least:
Absolutely. But a community-driven project depends on the number of users/contributors. 😉
Still, MATAA can not replace a real-time analysis software and this is what most RTX-Users will focus on.
That's getting a bit off topic, but (1) why do you think that most users will focus on real time analysis and (2) why would MATAA not be suitable for this?
I know my needs fall into the following categories,
1. Adequate management of measured data to collectively study the factors that influence sound coloration, and weight them.
2. Conduct series of measurements integrated into a design process to linearize the total system as much as possible.
3. Real time monitoring and logging of data to catch problems.
4. Criteria based data capture within a range before and after the criteria occurs.
5. Quality control metrics of measurements.
Sent from my iPhone using Tapatalk
There are many perspectives as to what "real time" refers to. Mostly, "as it occurs" is considered real time which you can associate the time stamp when it occurred and respective to other events occurring, but when you get to control systems, control loops are strictly controlled in different ways to preserve the gain and phase margins in multiple loops.
Real-time means being capable of capturing spurious events as well, which many analyzers cannot do. In spectral analysis of e.g. EMC one would need to capture burst events that are not periodic. For audio this could be useful depending on application.
Hello All,
What do you folks mean by "real time"?
By definition FFT is in the frequency domain, not time.
DT
In this context I understand "real time" as "show and process the data at the same time as things happen". Like in the attached video, which I made using playrec with GNU Octave on my Linux laptop mic/soundcard (quick and dirty!).
For my purposes "real time" means for example seeing the effect of adjusting the distortion trim on an ultra low distortion oscillator as I adjust it.
With a Shibasoku 725 the meter responds immediately as I adjust (probably 10 - 50 mS delay but its not perceived). Some software will show changes pretty quickly. Others really require running a test, processing and then displaying. Depending on the test that may be quick or may be really time consuming.
I hope this adds clarity.
Real Time is kind of a squishy topic
Real Time is kind of a squishy topic.
I recall, back in the day, I would walk across campus to the computer center and drop off a batch of IBM punch cards. Next day I would walk back across campus and pick up the cards and if I did not make any errors I would also get a print out. With the overnight latency there was no sense of real time analysis.
Real time is like real money, you do not want to spend it waiting.
DT
Real Time is traditionally used for software. Those fancy self-drive cars have real-time software. They better have!
The software that updates your account statement after you take money from an ATM doesn't need to be real-time.
The opposite of real time processing is batch processing. Banking software traditionally is batch-processing, like reconciling all accounts overnight. However, even banking software is slowly moving towards (almost) real-time processing.
Jan
