Patch Panel - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old Today, 02:00 AM   #1
skidave is offline skidave  United States
skidave's Avatar
Default Patch Panel
Quick project...got sick of wires, adapters, BNC T's and so on all over my bench.
I used blue plastic new construction conduit boxes from Lowe's and 1/8 inch plastic. I got a bag of 10 banana posts from Amazon dirt cheap and the rest of the connectors were stock items. Built my sound card attenuator into the panel and the switch selects divide by 20, 50 or 100.
I mounted my 2 USB audio interfaces below using Velcro for easy removal.
I have two different speaker loads for high power and low power--this is why I have two panels. I need to label the panels and then it is complete. All in all, I have four 8 ohm loads that allow me to flex what load I need.
I thought about building in a 10:1 BNC port, but I decided not to at this point and continue to just my scope probes when 10:1 is needed.
The Holmberg Patch. DrDyna Multi-Way 5 10th May 2012 07:01 PM
How to patch / fill aluminum panel? kruesi Construction Tips 6 3rd November 2009 02:13 PM
Cone Patch/Repair? Aesthetikz Multi-Way 5 18th September 2006 01:42 PM
The 'Tater Patch valveitude Tubes / Valves 17 13th July 2005 02:04 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
