Dull punch? - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 2nd May 2015, 04:44 PM   #1
Default Dull punch?
This punch looks a little dull to me. I can get it for $20. It's a Greenlee (comes with die and screw as well). Should I get it or should I look for a sharper one?
Also, can you sharpen them?
Old 2nd May 2015, 07:43 PM   #2
dchisholm's Avatar
Been a LONG time since I used one of those, but yes, they get dull with use. The cheap, off-brand imitations would show signs of dullness after only a dozen uses or so; the genuine items lasted much longer in the shops where I worked.
If you understand how the shearing action of these tools is supposed to work, it's probably worth the effort to attempt sharpening them. (Hint: DO NOT use a file or sharpening stone on the outer cylindrical surface!) A diamond paddle- or rod-style hone may do the trick. I'd also look at the opening of the mating die, to make sure the entrance has a sharp, square edge. As with the punch, do not file or hone the curved surface.
Dale
How can I dull the brightness of LEDs? hugz Construction Tips 47 17th October 2011 08:36 PM
Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY ppia600 Swap Meet 0 23rd February 2008 02:17 AM
My experience: the cheap punch set VS Greenlee punch vax9000 Tubes / Valves 5 21st July 2006 08:52 PM
one woofer is shiney and one is dull . . . Jimmy154 Multi-Way 25 19th August 2005 09:08 PM
Dull mind looking for speaker help justn Multi-Way 8 11th August 2005 07:50 PM
Copyright 1999-2017 diyAudio
