Mega328 Tester - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 5th March 2015, 07:44 PM   #1
Default Mega328 Tester
At the price of $22, I know it cant be that accurate, but how many of you all use it?
Looks like a fun toy to test good or bad components. And seems to beat the source to drain fight with transistors.
Worth the few bucks to test caps and transistors?
Is there a preference to different models?
http://www.amazon.com/SainSmart-Mega...nsistor+tester
Old 5th March 2015, 07:54 PM   #2
CoM is offline CoM  Canada
CoM's Avatar
Look on eBay too. It's under $15 US:
MEGA328 Transistor Tester ESR Meter Digital LED Diode Triode Capacitance MOS PNP | eBay
Old 5th March 2015, 07:58 PM   #3
Originally Posted by CoM View Post
I know, they do get pretty cheap. But Im learning there are different models/versions.
Was just curious if you all had a preference.
Old 5th March 2015, 08:09 PM   #4
CoM's Avatar
At under $15 there isn't much that you can regret.
Probably not extremely accurate but decent and going from nothing to this is a lot.
I say go for it. It's the best way to learn what you need without paying an arm and a leg (especially if something goes wrong and things heat up).
Of course I would like to have a Fluke or something with a well known name on it but then it will definitely cost more than a pack of 6 .
Old 5th March 2015, 08:23 PM   #5
For reference, here the link to the origin of theses testers:
Transistortester AVR - Mikrocontroller.net
Old 6th March 2015, 03:17 PM   #6
PedroDaGr8's Avatar
http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
Here's a big thread at EEVBlog discussing these testers including the one listed by the OP. The authors of the firmware post in from time to time, discuss the various branches of the firmware etc.
They quality varies a bit on these but they are decently competent. For an LCR, if you can swing for the under-$100 price point, there is a much higher value accuracy meter (Der EE DE-5000 which IET labs rebrands as their DE-5000 and DE-6000) but for around $20 this is about as good as you can expect to get.
Tube Tester maxseeley Tubes / Valves 0 5th January 2011 05:08 AM
Do you have a tube tester? pforeman Tubes / Valves 2 17th December 2010 04:25 PM
Matching Tester djoffe Solid State 1 23rd August 2009 07:58 PM
JFET Tester jackinnj Equipment & Tools 4 9th August 2008 04:43 PM
Have you seen this tester? smak Tubes / Valves 30 28th January 2006 06:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
