HP 3435A Digital multimeter quick fix - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 17th February 2015, 06:12 PM   #1
Default HP 3435A Digital multimeter quick fix
I recently bought a DOA HP3435A multimeter.
Those meters all seem to come with a battery backup 'Option' with a hefty NiCad battery pack and charger module in the lid. This meter was strictly for bench AC power use, and I have no interest in rebuilding the NiCad pack (which had been done once already, from what I could see).
There's a jumper location for non-battery use; using it brought back the meter from dead with blown fuses to working properly. I just left the charger/battery cable unplugged.
The service manual is available online, but I found the jumper from the clear printing on the PCB.
Good HP manuals link:
Index of /~kurt/manuals/manuals/HP Agilent
Re-flowing the solder on the switch connections seemed to clear up a small problem with volts/ohms LED 'confusion'.
It's nice working with good gear I could never afford when it was new.
Old 17th February 2015, 09:48 PM   #2
PedroDaGr8's Avatar
The battery pack option can often be used for ultra low noise measurements. If you don't need that, then just get it out of there so they don't leak everywhere.
Old 17th February 2015, 10:55 PM   #3
I've done that, now. Thanks for the tip.
quick tripath fix? infobot Class D 7 17th August 2013 11:23 AM
Digital MultiMeter? nelsondog Everything Else 23 28th August 2010 10:42 PM
HP 34702 Multimeter problem. es44 Equipment & Tools 0 31st October 2008 06:45 PM
need help with getting a digital multimeter ad_breaker Parts 14 19th February 2006 02:13 AM
Digital Multimeter speedstar Digital Source 2 20th July 2004 02:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
