Ebay Wire Stripper Suggestion - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 17th December 2014, 05:39 AM   #1
Default Ebay Wire Stripper Suggestion
Can anyone suggest a good wire stripper, preferably something less than USD15 from Ebay? Should be free shipping to my country as well, so i guess it's limited to Chinese products. I don't want to spend too much on something i can live without so far
Should i go with something that works like simple pliers or the "auto" ones where the wire gets clamped and stripped by one pull?
Old 17th December 2014, 07:05 AM   #2
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
I use this, and out of all strippers I have, I like this one the most. I have different brand that I purchased locally, but this type. I tried and own many, but this one works by far the best.
Velleman VTSTRIP4 Heavy Duty Wire Stripper Cutter Crimper | eBay
www.burningamp.com
Old 17th December 2014, 10:56 AM   #3
Ouch.. Velleman mucho dinero.
Anyway, i end up buying this Terminal Electrical Automatic Crimper Crimping Tool Wire Stripper Plier K0E1 | eBay
12 bucks shipped. If i manage to break it, not much money lost.
Thanks for the suggestion.
Old 17th December 2014, 11:48 AM   #4
Kiriakos's Avatar
Do not worry you are unable to break it, it would rust and die by it self.
Old 18th December 2014, 04:34 AM   #5
Master Burner
AR2's Avatar
That is it. The same type. You do not need to buy the same brand just the type. You did good.
www.burningamp.com
Old 18th December 2014, 05:24 AM   #6
dchisholm's Avatar
I have used that type from several manufacturers over the years. The biggest disadvantage is that most units of this type only go to AWG22 or AWG24.
I've been generally pleased with all of them, though the one I have now (I think it's from "Klein") seems to give consistent results with less mental effort than most of them.
Dale
Good all-round coaxial cable stripper tool earl of sodbury Equipment & Tools 4 26th February 2013 08:54 AM
good wire stripper for 26 gauge, which tool? gychang Equipment & Tools 30 21st June 2011 03:37 AM
EBAY DAC, Suggestion pls tony Ma Digital Line Level 7 18th June 2011 05:23 AM
why does teflon insulated wires need a very expensive wire stripper? jarthel Parts 7 30th April 2007 03:53 AM
teflon wire stripper sam9 Parts 15 12th February 2005 10:42 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
