TV-7D/U Tube Tester - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 2nd December 2014, 08:32 AM   #1
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Default TV-7D/U Tube Tester
I recently acquired very nice TV-7D/U tube tester, my what a piece of engineering!
Only issue is that none of the adapter sockets came with it so I'm going to build a copy of the E105 as I want to test a few 829b tubes.
So working with my DMM I've worked out the pin-out as this......
Octal Pin 1 - Septar Pin 4 - Cathode
Octal Pin 2 - Septar Pin 5 - Heater
Octal Pin 3 - Septar Pin 3 - Grid 2
Octal Pin 4 - Septar Pin 2 - Grid 2 of 1 (LINKED)
Septar Pin 6 - Grid 1 of 1
Octal Pin 5 - Fly lead - Plate 1
Octal Pin 6 - N/C
Octal Pin 7 - Septar Pin 1 - Heater (LINKED)
Septar Pin 7 - Heater
Octal Pin 8 - Fly lead - Plate 2
Has anyone got one of these that they could check my workings against?
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 3rd December 2014, 01:09 AM   #2
Dagwood's Avatar
No bites????
Someone must have one of these they can check for me?
Cheers
Old 3rd December 2014, 02:03 AM   #3
I get the following,
Octal Pin 3 - No Connection
Octal Pin 6 - Septar Pin 3
Octal Pin 7 - Septar Pin 1+7
I used this sheet as a reference for the Septar pinout http://www.tubecollector.org/documents/bases/diag24.gif
Old 3rd December 2014, 04:35 AM   #4
Dagwood's Avatar
Hi mcandmar
Thank you, Just had a look and your right.
Ill solder it up tonight and post some pics
Thanks again
Old 4th December 2014, 09:02 AM   #5
Dagwood's Avatar
[IMG]Click the image to open in full size.[/IMG]
Old 4th December 2014, 09:49 AM   #6
Very nice. Where did you get the right angle octal socket part?
Old 5th December 2014, 03:38 AM   #7
Dagwood's Avatar
Hey mcandmar
I think it came with a mixed lot of parts that a won on TradeMe (NZ Ebay)
They are very well made, but no marking on them??
Cheers
Hickok Tv-7D/U A Setting not working ofalfam Tubes / Valves 1 1st December 2013 04:54 PM
NOS TV-7D/U Tube Tester vintagekind Swap Meet 12 16th August 2012 03:16 AM
Will pay for....calibrate my TV-7 tube tester jmillerdoc Equipment & Tools 0 26th June 2011 05:05 AM
Testing Western Electric 437a with TV-7D/U ? HP8903B Tubes / Valves 0 10th April 2011 10:51 PM
TV-7D/U Tube setting --- 6550 Apex Jr Tubes / Valves 4 22nd November 2008 05:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
