Elenco F-1300 Universal Counter Timebase Mod - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 19th July 2014, 12:35 AM   #1
Default Elenco F-1300 Universal Counter Timebase Mod
Back in 2002 I purchased an Elenco F-1300 universal counter for US$220. The unit offered a high-resolution frequency function below 35 kHz that I thought would be useful for audio work. Instead of measuring the number of input cycles during a 0.1 or 1 second gate time, the F-1300 measures the number of cycles of the master clock during one cycle of the input and then calculates the frequency. Thus for a 1 kHz input you could read 1000.000 Hz with a fast update of the display.
The only issue I have with the stock F-1300 involves the stability of its crystal-controlled timebase. Perhaps the accuracy spec of +/- 10ppm/year with a warm-up time of 30 minutes (I measured close to 60 minutes to final equilibrium) is acceptable for some work. However, I felt I could do better. The timebase circuit incorporates a 10 MHz crystal with gain provided by an inverter from a 74HCU04. I thought the counter's performance could be improved by replacing the timebase circuitry with a temperature-controlled crystal oscillator (TCXO).
There are many possible TCXOs that one could use. I settled on a $20 unit I purchased on eBay from a Chinese company called LogiFind - stores.ebay.com/logifind/. Listed as an "Ultra precision Crystal Oscillator" the spec sheet said that precision was +/- 1 ppm with a 1 ppm/year max ageing rate. The supply current spec of 20 mA max shouldn't overtax the F-1300's regulated +5V supply. The oscillator comes in a standard metal DIP can with four pins. Pin 1 is no-connect so there is no possibility of voltage-controlled frequency trimming. Shipping to the USA was much faster than month or so quoted during the eBay purchase.
To mount the new TCXO I first removed the old timebase components - X32, R29, C34, C35, C36 and C361. The crystal and trimmer are thru-hole and have to be unsoldered from the board bottom which is easy to get to. Prior to mounting the TCXO I soldered a 0.047 uF decoupling capacitor between pins 7 and 14, about halfway up the can leads.
TCXO pin 8 solders to the C35 pad that goes to the R29 pad and then pin 13 of the 74HCU04 (U30). Pin 7 goes to the ground side of surface mount capacitor next to C73. Pin 14 touches the board near a via hole so I first insulated it with a bit of electrical tape on the board. Then I ran a wire from the pin to the +5V pad between C362 and C363. Finally to secure the TCXO I ran a thin cable-tie through the C36 trimmer hole, around the TCXO and back down the hole. See the photo.
I am very happy with the modification. Now after the counter powers up I get an instant reading of 10.000000 from a rubidium standard. The only down-side to this project is that the F-1300 has been discontinued by Elenco. You will occasionally see one for sale on eBay but I have not discovered any other source. But if you are able to obtain one, perhaps this mod will prove useful.
NAD 1300 - Problem with static dman535 Solid State 3 19th April 2014 01:20 PM
abletec alc1000-1300 fransiscan Class D 5 29th December 2012 04:48 AM
Technics SL-1300 without ground cubby2k Analogue Source 4 20th April 2011 09:09 PM
Amp cases, Borbely preamp, Elenco scope, aluminum Jason_N Swap Meet 10 9th July 2009 04:24 AM
celestion 1300 mekons123 Multi-Way 1 3rd November 2006 12:11 AM
Copyright 1999-2017 diyAudio
