soldering flux? - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 16th July 2014, 11:05 AM   #1
s214519 is offline s214519  United States
Default soldering flux?
Can regular soldering flux for like copper tubing be used to solder on a pcb?
Old 16th July 2014, 11:14 AM   #2
RJF is offline RJF  Australia
Not usually, it is too strong for delicate PCB work.
Why do you want to use flux on the PCB?
If it is a home made PCB (bare copper), clean it up with a mild abrasive and then use a solder through coating. If the PCB is commercially made they are usually HASL finished (solder plated) so do not need flux.
Modern Solders are usually rosin cored which acts as a flux anyway so do not need extra flux.
Old 16th July 2014, 11:24 AM   #3
I've never used flux on any of my pcb's. I just saw that they sell flux for it and was wondering if it would make it easier. But I have a ton of plumbing flux for copper tubing so I was asking if it would work and I was gonna try it.
Old 16th July 2014, 11:49 AM   #4
DF96 is offline DF96  England
No, definitely not! Plumbing flux could destroy a PCB. Use proper electronic solder wth built-in flux cores.
Old 16th July 2014, 11:51 AM   #5
^^ yeah that's what I usually use. I was just wondering if it would work. But thank you. I don't have to wonder anymore!
Old 17th July 2014, 02:18 AM   #6
PedroDaGr8's Avatar
Depends on the type of plumbing flux. There are two types: one is a white ZnCl2 based flux, the other is basically rosin paste. The rosin paste is 100% OK to use. It's the same stuff that is in rosin-core solder. The ZnCl2 paste is 100% BAD to use. The ZnCl2 leeches into the board and can turn the insulating board conducting. It is impossible to remove once used.
Old 17th July 2014, 09:50 AM   #7
Not 'could', WILL destroy the board. A fellow at work mistakenly used plumbing flux on board repair. The boards had to be tossed out - about $1500 each.
I also recommend cleaning off rosin fluxes after repairs as the old flux may burn and turn in to unplanned resistors.
When I repair SMD parts, I clean the board after the old part removal, put flux on each pad using a flux pen, place the part, solder it down and clean off the flux.
Old 18th July 2014, 08:02 PM   #8
No don't use the same flux. It will destroy your board. Soldering plumbing and electronics are very different. I would recommend using a good electrical solder with a rosin core like this one: .025" dia. Sn63/Pb37 Rosin Based Wire Solder (1 lb. Spool). You will have to clean the flux off though when your done. They do make no clean wire solder like this one: .020" dia. Sn63/Pb37 No Clean Wire Solder (1 lb. Spool). Which you wouldn't have to clean it when your done. I personally haven't used it but I know it's out there.
Hope that helped!
Old 18th July 2014, 09:04 PM   #9
If you need a good paste flux, The stuff that Radio Shack carries works great!!
It comes in a short plastic can and is Cat. No. 64-022 Non Spill Paste Rosin Soldering Flux.
2 oz. Non-Spill Rosin Soldering Paste Flux : Soldering Tools & Supplies | RadioShack.com
I used it on my very first SMD project and it turned out excellent!!!
As seen here,
Kester Lead-Free Hand-Soldering Article
FWIW
jer
Old 18th July 2014, 10:40 PM   #10
Pemo is offline Pemo  Mexico
Pemo's Avatar
No no no, no flux. (Well, only for de-soldering tasks)
And clean the damn thing inmediatly.
How do you remove flux residue after soldering? 777funk Construction Tips 43 22nd September 2015 11:05 AM
Soldering rca's ends with wrong flux deriklfixit Construction Tips 14 26th July 2013 03:29 AM
How to use flux dublin78 Construction Tips 13 23rd May 2012 09:48 PM
Soldering tips for soldering station BEST PRICE, FREE SHIPPING, 15% discount vtech9815 Vendor's Bazaar 0 27th January 2010 05:40 PM
What flux for soldering old brass? Pbassred Solid State 5 5th December 2007 11:35 AM
Copyright ©1999-2017 diyAudio
