8903A Error 14, power supply circuit diagram - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 15th July 2014, 04:20 PM   #1
usul27 is offline usul27  Switzerland
usul27's Avatar
Default 8903A Error 14, power supply circuit diagram
I have a HP8903B here that does not work. It always outputs "Error 14" which is an input signal above the measurement range. However there is no input signal. I couldn't identify the problem yet, but it seems to come from the front end board. When I remove this board, the analyzer starts and displays 0Hz, 0.003% THD+N. This seems reasonable. Now I have to find the problem.
One thing I noticed is the voltage on the +15V rail. It is only 13V. This doesn't seem normal to me. However I could not find the circuit diagram for the power supply. Does someone have a scan of it?
Any known issues that led to Error 14?
Thank you
Daniel
Old 15th July 2014, 05:09 PM   #2
expert in tautology
bear's Avatar
I think HP has the schematic on their site, iirc.
Sounds like a possible DC offset in the card you removed?
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 16th July 2014, 01:40 AM   #3
PedroDaGr8's Avatar
First thing to check is all electrolytic and tantalum capacitors. These are often the first thing to go in devices this old. After that, I would look for bad op-amps.
Old 16th July 2014, 01:44 AM   #4
expert in tautology
bear's Avatar
I have the SM, but the site refused to upload it.
If you for some reason fail to get it off the HP/Agilent site, PM me with ur email and I can attach it - it's two parts pdf, and about 20meg each part.
_-_-bear
Old 16th July 2014, 01:53 AM   #5
WSJ is offline WSJ  United States
WSJ's Avatar
Manuals
Technical Support: 8903B 20 Hz to 100 kHz Audio Analyzer [Obsolete]| Agilent
Old 16th July 2014, 07:30 AM   #6
usul27's Avatar
Thank you, I've got it. The 13V on the +15V rail are clearly out-of-spec. I will start here.
Old 17th July 2014, 02:58 AM   #7
1audio is offline 1audio  United States
You may have a shorted cap in a supply or a bad input opamp or protection diode. Either would give the error message your mentioning.
Demian Martin
Product Design Services
Old 18th July 2014, 11:35 AM   #8
usul27's Avatar
Yes, at least one capacitor in the power supply failed. I'll start by replacing this one.
Old 18th July 2014, 01:49 PM   #9
PedroDaGr8's Avatar
Replace as many electrolytic capacitors as you can because in old equipment they are often ticking time bombs.
Old 18th July 2014, 02:04 PM   #10
usul27's Avatar
Yes, I think this makes sense. There are 3 huge screw-in caps in the power supply. Is there any reason to use these huge screw-in models? Modern electrolytic capacitors with same capacity/power rating would be much smaller.
Lowther LL18S stereo power amplifier - circuit diagram? EC8010 Tubes / Valves 15 16th November 2013 07:51 PM
circuit diagram for cambridge A70 power amp rollei Solid State 1 13th December 2011 01:14 AM
circuit diagram for LMI-32216A RCA ORTHOPHONIC POWER AMPLIFIER renjiish Tubes / Valves 4 12th March 2011 09:18 AM
Need high quality 12-14.4v power supply stephenmarklay Power Supplies 4 9th January 2010 03:44 AM
Help.. EZ81 power supply diagram dudong Tubes / Valves 2 12th April 2007 02:32 PM
Copyright 1999-2017 diyAudio
