8903A Error 14, power supply circuit diagram - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 18th July 2014, 05:30 PM   #11
1audio is offline 1audio  United States
If you are troubleshooting the mass replacement of parts can hide a real problem. Its important to chase down the root cause before doing preventative maintenance. A low supply probably is not a cap. They usually fail as shorts or opens. Its really annoying to replace a bunch of parts and have the original cause of the failure fry the new parts. The power supply regulator will dump power into a partially failed cap heating it up until it fails completely. A supply running low should be checked in a more thorough way. Start by disconnecting the loads (pulling cards) and check the supply voltage. Also look for signs of overheating. Burnt resistors or PCB would be a good indicator of a failed part.
Demian Martin
Product Design Services
Old 18th July 2014, 05:33 PM   #12
Replacing the computer grade caps in the supply with new caps will be a good long term thing. The screw terminal caps are passing. However getting a suitable replacement that will work in the space may prove more difficult than you expect. Long leads will compromise the cap performance.
Demian Martin
Old 22nd July 2014, 08:12 AM   #13
usul27 is offline usul27  Switzerland
usul27's Avatar
The 13V were the problem. Oscilloscope showed heavy ripple on this voltage rail. The electrolytic cap failed. Replacing it solved the problem. Now the analyzer is workign again. I will also replace the other 2 caps in the power supply in the next time.
Lowther LL18S stereo power amplifier - circuit diagram? EC8010 Tubes / Valves 15 16th November 2013 08:51 PM
circuit diagram for cambridge A70 power amp rollei Solid State 1 13th December 2011 02:14 AM
circuit diagram for LMI-32216A RCA ORTHOPHONIC POWER AMPLIFIER renjiish Tubes / Valves 4 12th March 2011 10:18 AM
Need high quality 12-14.4v power supply stephenmarklay Power Supplies 4 9th January 2010 04:44 AM
Help.. EZ81 power supply diagram dudong Tubes / Valves 2 12th April 2007 03:32 PM
Copyright 1999-2017 diyAudio
