Kester Lead-Free Hand-Soldering Article - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 2nd July 2014, 04:10 PM   #1
6speed is offline 6speed  United States
6speed's Avatar
Default Kester Lead-Free Hand-Soldering Article
My go to solder for audio projects is Kester 44 - 0.031" Sn62Pb36Ag2. Working on more SMD stuff lately, this size is ok but I was looking to order some 0.15" solder to make my life easier. Which led me to revisit lead-free solder. My past experiences with lead-free have been not so good so this article from Kester caught my attention :
Lead-free Hand-soldering Ending the Nightmares
For my level of experience with lead-free this was exactly the type of information I was looking for it talks about the different types, temperatures, tip choices, inspection changes and even has transition steps.
I just wanted to link it here in case anyone else found it useful as well.
Cheers
Old 2nd July 2014, 04:39 PM   #2
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
good info.
thanks for sharing.
mlloyd1
Old 3rd July 2014, 12:12 PM   #3
SyncTronX's Avatar
Always good to get info.
Thanks gearhead.
-- Sync
Old 4th July 2014, 01:47 PM   #4
I have had good luck with the stuff found at Radio Shack as well.
The non-spill rosin flux paste they have (Cat. 64-022) is a must have and makes everything much easier.
Here are some pictures of my very first attempt at SMD and it was much nicer and easier that I had expected!!
I used the RS Cat.64-1013 .022" 62/36/2 on this TSSOP package and it worked very well.
I haven't gotten any of the thinner stuff (.015") yet but I plan to give it a try as well.
Once I got the .022" home, I had realized that I maybe should have gotten some thinner stuff, but it worked.
Actually I was skeptical to use the stuff because it was silver based and I have used silver based solders before.
FWIW
jer
Old 7th July 2014, 02:00 AM   #5
6speed's Avatar
Nice work indeed!
I agree on the flux. Also cleaning the pads with iso alcohol and kim wipe then fluxing then soldering makes a really big difference on how things go. I have had good luck with the Kester Rosin pens they put down a tacky flux that holds the little buggers in place but clean-up's not as easy. My usual is a needle dispenser type my current is a Metron RMA sourced from All-Spec. Clean-up with it is very easy and it is the liquidy type so it provides a satisfying sizzle before the solder melts
RohS lead free soldering richwalters Everything Else 104 16th March 2008 03:33 AM
Lead free soldering! Pan Solid State 15 22nd November 2007 07:37 PM
Lead free soldering anyone? studiotech Equipment & Tools 2 24th August 2005 11:56 PM
silver/lead-free/copper soldering alloys metebalci Parts 1 5th May 2004 04:33 PM
Copyright 1999-2017 diyAudio
