Audio Precision System 1 relays - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 26th June 2014, 12:27 AM   #1
Loudthud's Avatar
Default Audio Precision System 1 relays
My Audio Precision System 1 (config -11S) has a bad relay (I'm guessing) on the Generator output attenuator. As you try to adjust the output (unbal-float) below 330mV the output jumps up to 931mV and maintains about an 8.5dB error as the output is adjusted lower.
There are 8 IIRC DIP relays between the output transformer and the front panel, I'm guessing these form part of the attenuator for generator output. There is also a DAC somewhere that is used to adjust generator output. Should I just socket and replace the relays? Do I need special relays or will cheap telecom types be ok?
Old 28th June 2014, 04:13 PM   #2
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
The relays may be the same as A_P uses on new models. Might give them a call to se if they will sell you one or give mfr/pn for an exact replacement. A-P should be able to help you... thy are very customer friendly.
-RM
Old 4th July 2014, 06:19 AM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
Google or Bing whatever numbers are on the top of the relay. That's how I identified the COTO relays used in one of my HP instruments.
~Tom
Modulus-86: Composite amp achieving 0.000067 % THD. Damn Good 300B, Novar Spud, 21st Century Maida Reg., Filament Reg., etc.
Neurochrome : : Audio - http://www.neurochrome.com - Engineering : : Done : : Right
Old 5th July 2014, 12:29 AM   #4
I bought mine from AP for around $6.00 each.
Art
Audio Precision System Two - 2322 eboz Swap Meet 2 18th July 2013 03:16 PM
Audio Precision System 1 mickeymoose Swap Meet 4 23rd April 2010 06:47 PM
Audio Precision System One 11G Michael Rothacher Swap Meet 7 19th April 2010 12:53 PM
Audio Precision System One for sale marcreviel Swap Meet 0 2nd December 2002 05:18 AM
Audio Precision System One 02G Michael Rothacher Swap Meet 0 22nd November 2002 03:17 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
