Oscilloscope for a beginner - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 10th May 2014, 06:10 AM   #1
Default Oscilloscope for a beginner
sorry but i got lost in all the 3Ds talking of scopes and i have not been able to understand much.
I am a very beginner and without any real knowledge, so i need something easy to use.
My main, almost only, interest is to check the noise from some DIY power supplies up to 100 V for audio project (preamps).
So I suppose i do not need a big bandwidth, but maybe sensitivity ?
To start i would like a cheap but easy to use scope with a sub connection for the PC
I saw a Member recommending something like this one here
Hantek 6022BE PC-Based USB Digital Storag Oscilloscope 2Channels 20MHz 48MSa/s | eBay
As i said i need it only to check noise out from power supplies
And possibly the ability to generate a sweep 20-20.000 Hz would also be very very much appreciated
Thanks a lot and kind regards,
gino
Old 10th May 2014, 06:18 AM   #2
Mooly's Avatar
Easy one first. For a 20 to 20kHz sweep you can use "Audacity"
Installing and using Audacity. A get you started guide.
The scope I have no experience of other than to say that these cheap PCB based tools are of limited value compared even to a modest spec analogue scope. The spec mentions "input gain range" of 20mv to 5 volts. If that is an equivalent of "volts per division" then its limited. A typical analogue scope would go down to 1mv.
For the price though, they are very good and you will learn a lot.
Old 10th May 2014, 06:41 AM   #3
Thank you very much indeed. I will study this immediately.
Thanks again
This is really my main need. And actually a 1mV sensibility would be very nice indeed.
I wonder which other models of pc based scopes could give me this kind of value.
Are they much more expensive ?
i could do a little bigger effort for something that i could use also when i will have some more experience (i.e. not a toy)
In particular i like very much to get noise spectra like this one here
Thanks a lot and kind regards, gino
Old 10th May 2014, 06:56 AM   #4
Mooly's Avatar
I honestly can't really advise on the scope, I've no experience of the PC based ones at all. The picture looks as though its using something far more sophisticated and higher specced tbh, particularly when you look at the levels and frequencies.
Wait and see what others think
Old 10th May 2014, 07:20 AM   #5
Thanks a lot again. Kind regards, gino
Old 10th May 2014, 07:25 AM   #6
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You look for many bits of resolution and the audio spectrum. Just AC couple with a capacitor to a PC soundcard and use a program like ARTA.
Old 10th May 2014, 07:32 AM   #7
Hi and thanks for the suggestion
I guess you mean this one
ARTA Download
I will try it for sure. Thanks a lot.
gino
Old 10th May 2014, 08:29 AM   #8
I might want to consider taking a look at Visual Analyzer as well!
Exploring Visual Analyser (VA)
It is a sound card based scope that does most everything you would need within the audio range.
It is great for learning the basics of scope controls as well as many other very viable tools such as an RTA a THD meter ,and , impedance measurements that are included and it is free!!
Once you learn calibrate and work with it you will find that it is very accurate!!
http://www.esldiy.com/index.php?topic=176.msg310#msg310
But you can't beat a good decent quality analog scope either!!!
FWIW
jer
Old 10th May 2014, 01:05 PM   #9
The Visual Analyzer VA 2011
Hi and thanks a lot ! lots of functions indeed
I am mostly interested in noise spectra from power supply
But some more flexibility is clearly welcom
I will study it
FWIW
jer
What can be considered a decent entry level for this ? how much would it cost ? just to have a reference
Thanks again, gino
Old 10th May 2014, 01:16 PM   #10
Mooly's Avatar
Something like this would be a minimum,
Hameg 20MHz Oscilloscope HM203-6 GWO | eBay
No traditional analogue scope will do FFT analysis which is what your picture shows.
Beginner Help. SonicLife18 Power Supplies 2 11th July 2012 11:19 PM
Help for beginner catorg Full Range 7 23rd January 2012 01:57 AM
Beginner tareqx2 Multi-Way 19 22nd August 2007 05:53 PM
Help for a beginner? fishwinker Solid State 0 26th September 2005 08:52 PM
sorry, another beginner (hopefully soon) zach Solid State 3 18th January 2002 12:48 PM
Copyright 1999-2017 diyAudio
