Tek 7a13 repair - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 5th April 2014, 12:31 AM   #1
davada is offline davada  Canada
Default Tek 7a13 repair
I have a 7A13 with a broken shaft coupler. Does anyone know where I can find small mechanical parts. Shaft couplers, universal joints those sorts of things for electronics switches or pots etc?
David.
Old 5th April 2014, 01:11 AM   #2
WSJ is offline WSJ  United States
WSJ's Avatar
Buy a bad one on eBay, then you will have a complete set of parts minus the bad one.
Old 5th April 2014, 03:02 AM   #3
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Try an RC Hobbies store.....all sorts of cool mechanical bits.....shaft extenders, universal joints, you name it.
Dan
Old 5th April 2014, 03:44 AM   #4
Great idea.
Thanks Dan.
David.
Old 5th April 2014, 04:10 AM   #5
Default You're Welcome...
Have a good look on eBay also.
Dan.
Old 5th April 2014, 05:28 AM   #6
I'd throw it at the Tek Yahoo group. There might be someone with spares.
Samuel
Old 5th April 2014, 05:46 AM   #7
It's the entire gear box that's broken. The coupler or Ujoint is just a make work solution.
I got the PI for free. Just the cost of shipping.
David.
Old 6th April 2014, 09:00 PM   #8
1audio is offline 1audio  United States
Look here if you can't find the original parts: Manufacturer of Precision Components | Spur Gears | Sprockets | Timing Belts | Timing Pulleys | Miniature Bearings | Shafts | WM BERG Engineered Mechanical Components It must be a first gen with the mechanical readout.
Demian Martin
Product Design Services
Old 6th April 2014, 09:09 PM   #9
Originally Posted by 1audio View Post
It is a first generation with the mechanical display.
I bought an assortment of these off ebay. They were dirt cheap. I'll give them a try and failing that...
These are a flexible beam shaft coupler intended for CNC.
David.
Old 8th April 2014, 01:44 AM   #10
Loudthud's Avatar
That mechanical assembly was a nightmare from day one. The engineer that designed it had to shim every one of them in production.
Tek 465 repair buzzforb Equipment & Tools 4 20th January 2013 12:23 AM
tek 454 jechentau Equipment & Tools 2 26th September 2009 07:07 PM
Tek vs Tek ak_47_boy Equipment & Tools 9 11th June 2007 05:27 PM
New TEK Scopes Bryan Tubes / Valves 22 25th November 2005 12:56 PM
TEK 7623A repair ? + other 7623A related questions Bernhard Equipment & Tools 5 29th July 2003 03:33 AM
Copyright ©1999-2017 diyAudio
