Eico 221 VTVM - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 12th March 2014, 02:40 PM   #1
jblmar is offline jblmar  United States
Default Eico 221 VTVM
I'll be making new probes for the 221. The manual specifies shielded cable for the DC Probe. Is this really necessary? I would like to use a single pair for AC/DC & Ground. What cable should I use?
50 ohm?
75 ohm?
RCA cable?
Other?
Does it matter? Sorry, I'm new to VTVMs.
In addition, I would like to solder the 15 mega ohm resistor to the DC Jack of the VTVM not at the tip of the DC probe not to make a separate probe. Any downside to doing this?
I'll change the original jacks to Banana Jacks as well.
Your opinions welcome.
Old 12th March 2014, 05:37 PM   #2
akimmet is offline akimmet  United States
Since the meter is high impedance, a small amount of capacitance or a em field can wildly influence your measurement. Yes, the probe needs to be shielded cable. The external resistor needs to be as close to the probe tip as possible as well. I would recommend either re-using the stock connector, or at least using a connector that ensures the shield on the cable is connected to the ground probe when plugged in.
I have a RCA WV77E with unshielded probes, and it is nearly useless. The meter needle has a mind of it's own, touching the probe cable will peg the meter on most settings. I haven't gotten around to making an appropriate probe for it, because I have a nice heathkit VTVM that works perfectly.
Last edited by akimmet; 12th March 2014 at 05:47 PM. Reason: added comment on bananna jacks
Old 12th March 2014, 06:49 PM   #3
Thanks akimmet for your reply. I can use the original probe with a new resistor and shielded cable. The original jack had a sloppy connection to the probe connector, so I'll go with Banana jack & connector.
I'll try the resistor both in the probe and then soldered to the jack to measure it's performance to see what the differences are.
Your opinions are welcome. Keep them coming.
Eico 221 VTVM Reguild jblmar Equipment & Tools 7 23rd October 2013 04:40 PM
Eico 221 VTVM Probes jblmar Equipment & Tools 6 10th October 2013 11:31 PM
Eico NOS Mdl 232K VTVM Peak-to-Peak VTVM KIT UNOPENED HolySmokes Swap Meet 0 27th January 2012 11:01 PM
Danley TH-221 drawings ? matsj Subwoofers 37 23rd January 2012 11:04 PM
Eico 221 Voltmeter jdeitch11 Swap Meet 0 22nd February 2011 08:35 PM
Copyright 1999-2017 diyAudio
