Measurement mic calibrated - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 3rd March 2014, 07:22 AM   #11
1audio is offline 1audio  United States
The B-5 is still an electret. Even many of the B&K's are electrets. You can get the Behrenger ECM8000 for $60 at Amazon. This is also sold by a number of other people with different names. they are all good. Here is the spec sheet: http://c3.zzounds.com/media/ECM8000_...4844659eb5.pdf
Demian Martin
Product Design Services
Old 3rd March 2014, 08:22 AM   #12
I have to find a local EU Supplier. Var and freight Will more than double the US prices
Old 3rd March 2014, 08:23 AM   #13
As far ad I know all the look a likes are from Superlux including the Behringer
Old 3rd March 2014, 08:49 AM   #14
Check this out as well:
Cross·Spectrum - Calibrated Dayton Audio EMM-6 Microphones for Sale
Hobbyists seem to turn to USB mics nowadays, for obvious convenience reasons.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 3rd March 2014, 10:03 AM   #15
Yes I can get from Germany
https://www.intertechnik.de/Shop/Zub...8,de,220,96418
And they also have some other stuff I need, so might go for that one. USB is always more expensive than XLR and since I have a good preamp with phantom I will go for XLR.
The alternative is and uncalibrated superlux from Thomann
Superlux ECM999 - Thomann Danmark
But the difference is only 10€.
Old 6th August 2014, 07:27 AM   #16
Send a message via Skype™ to Mario Pankov
Originally Posted by Kjeldsen View Post
I will se if I can get a used Beyerdynamic MM1 - if not I will just go for an uncalibrated superlux ecm999.
Hej,
I had the ecm999 and today received back the MM1 from HiFi Selbstbau in Köln who calibrated it. As it was requested by the ecm999 buyer, I run a reference curve under specific conditions on one of my home speakers, which I still keep on my laptop. Can run a curve with the MM1 today, air temp and himidity are the same ( himidity is slightly higher though ) and post the two frequency responses so you can compare how much of a difference it is between the cheap Superlux and the MM1.
The bigger problem with cheap mics is not the frequency response, this can be calibrated. It is the distortion of the mic under specific SPL. Most cheap mics don`t even state their max SPL, neither at what distortion level it was measured ( eg. 1% or more ). This is serious because when you run a nearfield measurement at 0 degrees the SPL at the capsule, right at the dust cap of the driver, would be very high, typically above 120db. Second problem is the size of the mic tubing, cheap mics are large, where the MM1 for example or some of the B&K stuff is thin and very narrow.
Besides the issues above, an uncalibrated cheap mic would still produce reliable frequency and phase response in the 500-5Khz band. If you need it for home measurements, your gating frequency would usually be around 500-700Hz so not a big issue, the tweeter, if placed on a baffle, could also be ignored above 5Khz ( if measured alone it would have ragged response in the 5-8Khz band ). You`d need to buy a mic stand and measure properly - the mic`s axis should be the same as the stand`s arm axis to reduce reflections.
Old 6th August 2014, 08:32 AM   #17
Thanks, but you don't need to measure - another problem with these cheap mic's is that the freq response vary a lot. You can't even now if the capsule is the same from batch to batch.
I do have the Superlux and I just accept that my measures might not be that accurate below 500 Hz and above 5000 Hz.
Cheapest Calibrated Mic Ever aborza Equipment & Tools 2 19th June 2013 11:57 PM
Now there is no excuse not to have a calibrated mic cuibono Multi-Way 54 20th December 2009 01:09 AM
recommendation to have mic calibrated mcmahon48 Multi-Way 2 18th September 2009 07:40 PM
Calibrated Behringer mic, software Thunau Group Buys 2 29th November 2007 03:57 PM
'Tube' preamp bad for measurement mic? also Apex mic question morbo Multi-Way 10 23rd March 2005 10:19 AM
Copyright ©1999-2017 diyAudio
