Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 13th February 2014, 09:48 PM   #1
Talking Idiot's guide to test equipment part 1 freq response
OK, I'm sure there is a thread on this, or maybe it is so basic I should already know, but I couldn't find one. I have a function generator which I am going to check is accurate and a 'scope. To measure freq response of a preamp, mic head amp, etc not power amp I am assuming I can:
1. use a DMM or VTVM and measure the AC voltage out on the function generator at say 10Hz and 40kHz and the 1kHz output and make sure they are the same;
2. Connect the DMM to the output on the amp;
3. Connect the 1kHz to the amp and measure the voltage out from the amp;
4. Hook up the 'scope and get a good trace;
5. I don't have a sweep generator, so manually move the frequency around and measure the roll off, convert the voltage difference to dB. (Although that is another question.
Or is this way to complicated? Just use a good soundcard, do the same to make sure the function generator is flat, make sure the card is flat then use software? I have a Delta 66.
NOTE: The guy on Facebook is not me. www.bluejinn.org
Old 13th February 2014, 10:21 PM   #2
SY's Avatar
You'll likely get a fail right there.
Bingo. Most software will even compensate for non-flat response of the soundcard, if such is the case (unlikely).
"The way to deal with superstition is not to be polite to it, but to tackle it with all arms, and so rout it, cripple it, and make it forever infamous and ridiculous."- H. L. Mencken
Old 14th February 2014, 06:21 PM   #3
expert in tautology
bear's Avatar
Actually, many if not most VTVMs are broad band, although perhaps not RMS reading. Heathkits for example are/were.
Regardless, any decent scope is dead flat in the audio band.
The main issue with soundcards is that they will not measure into the ultrasonic range (if you need that) AND it is very easy to blow up the front end with over voltage. Not so with ur scope in this application.
But the question is what are you measuring? Line level, amplifier level or speakers?
How much accuracy do you need, and what's ur aim?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- [...2SJ74 Toshiba bogus asian parts - beware! ]
Old 14th February 2014, 09:51 PM   #4
I do have a VTVM which is RMS reading (HP400)
Good to know! I only need the audio band, although I just acquired a 60Mhz scope.
Line amp, not power amp. (Preamp, mic head amp mostly) and tape deck. So no more than a few volts.
I will be building a compressor and need to know it's frequency response. I have a handful of pre-amps, and one claims to be "hi-fi." I'm curious as to how hi is that fi. as well. Just needs to be close enough.
Thanks for the response!
Idiot's Guide to the 49810TB Spasticteapot Chip Amps 15 31st July 2008 09:36 PM
TL freq response bigwill Subwoofers 6 13th July 2005 07:02 PM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
how to measure freq response skyraider Solid State 23 20th January 2004 07:08 AM
Need an anechoic Freq Response Test System Marcus Everything Else 2 14th March 2002 11:55 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright Đ1999-2014 diyAudio
