Measuring problems - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 27th January 2014, 07:46 PM   #1
JAV is offline JAV  Denmark
Default Measuring problems
Hi guys.
I've some problems with my new mic/Behringer 8000 with Clio 10FW.
I've measured three tweeters (R29, D30 and SB29). The pattern/peaks are the same every time.
Here of the SB29 - mls and sinusoidal.
What causes this ? Any thoughts ?
Thx.
Old 27th January 2014, 08:04 PM   #2
just another
wintermute's Avatar
I'm not familiar with Clio, I'm wondering whether you are getting feedback. Also strange that there is such a big difference between swept sine and MLS (they should be almost identical).
Check your sound card settings and make sure that what you are recording is not being sent back out to the speakers (often a tick box called something like "record without monitoring").
You could try downloading holmimpulse and see whether you are getting similar issues, this will give you an idea as to whether it is a hardware or software issue.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 28th January 2014, 05:26 PM   #3
Hi Tony.
Thanks for your feedback. I've tried different soundcard/Clio-mic settings in the software with no succes.
I do not understand the big differents between the measurements.
Whatever is measured in the sinusoidal mode, does obviously occurre in the MLS to.
But i've no clue what causes it.
Any respons is most appriciated. I've written to audiomatic and awaiting some feedback from them.
Old 29th January 2014, 12:58 AM   #4
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
How were the tweeters mounted for measurement?
-RM
Old 29th January 2014, 04:15 AM   #5
Both results are ghastly. S/N ratio based on LF content is non existent.
What are you driving tweeter with?
Have you verified that microphone isn't defective?
What are you using for preamp?
Is phantom power even turned on?
Old 29th January 2014, 06:45 AM   #6
VaNarn is offline VaNarn  Australia
The phantom power from the Clio system is 8.2 V which suits the Clio Mic-01 or 02 microphones.The Behringer needs a 15 V or higher D.C. supply and most likely needs the addition of a suitable preamp to work with the measuring system.
Old 29th January 2014, 02:37 PM   #7
Thanks for your respons, guys.
Marsh -> He is pic with the D30 mounted in the speaker:
Barley -> What do you mean by "driving the tweeter with" ? No, i've not yet verified if the mic is defekt. I'm not using an amp - as far as i understand, i can just use the internal amp with Clio 10FW. So Output-> XLR/crcocodile is directly connected to the tweeter. In the manual it says, it's no need to use the 12V input, when i'm using firewire 6pin/6pin cable.
VaNarn -> Oh my.. what kind of supply, would work with the mic and my Clio ? Bare with me :-)
Old 29th January 2014, 03:02 PM   #8
Sonce is online now Sonce  Macedonia
No, Clio 10FW do not include amplifier which can drive loudspeakers directly. You must use CLIO QCbox model 5 power amplifier, or any hi-fi amplifier capable of several W output.
Old 29th January 2014, 04:28 PM   #9
1audio is offline 1audio  United States
Are you doing ground plane windowed measurements? The measurement window looks wrong per your plots. You are getting input from reflections and possibly ambient noise.
Getting the right supply voltage for the mike is important,especially for its sensitivity calibration. Also the preamp may misbehave if the suply is too low. Using clipleads to connect a mike signal will also capture lots of emi which you don't want.
This stuff is never as simple as it looks.
Demian Martin
Product Design Services
Old 29th January 2014, 05:57 PM   #10
I should have noticed that your output level window was set at 1 V.This indicates that you are driving your speakers for a frequency response level sweep using the control box without an amplifier,i.e. you have a series resistor added to the speaker impedance,forming a voltage divider.You will need an amplifier and a kit based on a LM3875 i.c. (or similar) would be suitable for this application.Also a precaution when testing tweeters ,is to open the 'settings' dialogue box,the yellow symbol with the two ticks (on the line ,to the right of the green start arrow) and alter the L.F. limit from the 10 Hz setting to say,500Hz. For phantom power an 18V supply can be made from two 9V batteries ,plus a switch ,but they and the wiring must be shielded from EMI and RFI.
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS Tubes / Valves 18 6th July 2010 12:14 AM
problems measuring overcurrent in UcD output stage zilog Class D 44 27th April 2006 01:50 PM
how is it measuring? fumihiko Digital Source 18 24th January 2005 04:10 PM
Problems in Measuring 200mV in audio range (AC) r_s_dhar Everything Else 2 17th June 2002 05:01 PM
Copyright 1999-2017 diyAudio
