Current thoughts on transistor matching - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 13th January 2014, 01:49 PM   #1
tvrgeek is offline tvrgeek  United States
Default Current thoughts on transistor matching
Done this a lot, but I always wind up with a kluge on a perf board. I am about to build a new amp and need to match both low power BJT as well as high power outputs. Not looking for a full blown old Tek curve tracer. Are there any "simple" boxes out there to match for Beta at various loads better that 1%?
Old 13th January 2014, 05:08 PM   #2
skidave is offline skidave  United States
skidave's Avatar
Have you looked at this device:
AnaTek Corporation - Peak Atlas DCA75
I don't have one yet, but it looks valuable. This is a slightly newer versions with USB connectivity Vs the original model.
Dave
Old 13th January 2014, 08:05 PM   #3
That looks really cool for low power devices. Curve tracer too! I had not seen it. It will take some reading and maybe that will lead to others.
For output matching, I would think I would want to match at the minimum, at quiescent, so I need 130mA or more. Even the last set of inputs I did came out different at half a mA than 2mA.
Old 13th January 2014, 08:10 PM   #4
Accuracy not that good. Can't tell if their specs are absolute, or if their relative accuracy is actually much better. Kind of fixed at 5 mA Ic. Would sure tell you good or bad though.
Old 14th January 2014, 04:21 PM   #5
Mr Evil is offline Mr Evil  United Kingdom
You could try "locky_z's intelligent curve tracer", which is capable of up to 2.5A, so it can cope with power transistors. They come up for sale on eBay every so often. I have one myself, and it works very well.
https://mrevil.asvachin.eu/
Old 14th January 2014, 07:48 PM   #6
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
here is another choice for you: DUOYI model DY294 transistor tester. Also available from MIB Instruments --> www.mib-instrumenets.com
-RM
Old 14th January 2014, 08:18 PM   #7
nigelwright7557's Avatar
Dave
I have one and was impressed with it.
It doesn't even care how you connect it up.
I was having trouble with an amp oscillating and it showed the HFE of my new transistors was far too high.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 17th January 2014, 10:17 PM   #8
HIGH? Doesn't that give you some opportunity to tweak some things? My problem on my Hafler rebuild some time ago was some OnSemi that came in at half the minimum or worse.
Kind of looks like I should stick with my breadboard or find an old Heath. If I needed yet another DVM, I might grab one with an hfe range. 5 is enough for now. A curve tracer is way out of the budget.
Old 21st January 2014, 07:21 PM   #9
Build Rod Elliot's Transistor matching circuit. Works a beaut!!
transistor matching? millwood Solid State 10 25th December 2016 11:02 PM
Transistor matching diy didi Solid State 2 19th January 2012 02:01 PM
Transistor matching graham-r Parts 1 6th May 2009 07:21 PM
transistor matching derekyu Solid State 38 26th May 2007 07:57 AM
transistor matching weinstro Parts 28 6th July 2003 02:52 PM
Copyright 1999-2017 diyAudio
