Help finding probes for an Iwatsu SS-5702 20mhz Oscilloscope - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 29th August 2013, 11:57 PM   #1
CxTurbo is offline CxTurbo  Canada
Default Help finding probes for an Iwatsu SS-5702 20mhz Oscilloscope
A friend of mine got me an old Iwatsu SS-5702 20mhz 2-channel scope to play and learn on. I am having a hard time finding probes for it though. The scope that I have has Binding posts instead of BNC's for the probe inputs.Most of the photos and information I have been able to find on the SS-5702 shows that there are BNC's where my binding posts are. There is no information regarding probe type in the user manual I found online except calibration procedure.
Does anybody have any advice on possible probes choices,adapters or other options?
James
Old 30th August 2013, 12:06 AM   #2
KatieandDad's Avatar
As you are seeing most probes are BNC. Why not replace the Jap sockets with BNC.
Old 30th August 2013, 12:07 AM   #3
hongrn is offline hongrn  United States
hongrn's Avatar
Google "BNC-banana" adapter to see if that will do the job. Then you can get regular probes for your scope. Good luck.
Old 30th August 2013, 12:46 AM   #4
The thought had crossed my mind. Are the BNC's then just grounded through the case or would there be some form of input signal grounding? I have yet to open it up and peak at what would be required. I assume that the binding posts are isolated but again I have not investigated that far just yet.
As far as the adapters I tried to search but found most were the wrong gender and although I could probably use a coupler or gender changer. I would prefer not to go that route.
Thanks for the ideas.
Old 31st August 2013, 10:06 PM   #5
Enzo is offline Enzo  United States
I have both gender adaptors on my bench. One of my scopes is the Tenma with function generator. The genny has BNC output, but I have an adaptor on that for dual banana female. I use one vertical channel to monitor output of amps a lot. I have a bnc to bnc cable into that channel, at teh free end I have a bnc to banana mnale adaptor so the cord can plug into my speaker patch bay.
Both gender adaptors are readily available.
For example from MCM:
banana male
Dual Plug to BNC Female Banana Adaptor | 27-1040 (271040) | Distributed By MCM
banana female
Dual Binding Post to BNC Male Banana Adaptor | 100-2720 (1002720) | Distributed By MCM
Old 1st September 2013, 12:04 AM   #6
I saw those adapters in my searching. The problem is that this scope has single binding posts in place of the normal BNC plugs.Click the image to open in full size.
Old 1st September 2013, 03:23 PM   #7
Jsixis is offline Jsixis  United States
I'm no expert but it looks like that scope has a separate ground, right below the bottom left of your screen.
The adapters shown earlier would work, the only time you need the ground on normal oscilloscope probes is on sensitive timing circuits.
Invalid Request
^^ That should work, hopefully you can find a lower cost.
Old 1st September 2013, 04:04 PM   #8
I am normally not a huge fan of multiple adapters/connections if it can be helped. I could use the double banana to female BNC adapters with a banana to banana test lead between the scope and the probe but am not sure how bad it would degrade the signal. If at all. Or, can this be compensated for with the calibration function? If you all feel that this is non-issue then I will do just that and begin my scope education. As those dual adapters are more accessible and cheaper to boot. Banana to banana test cables are also easy to come by on the cheap.
Jsixis; That is exactly what I was looking for in the beginning. The only ones I found up to this point however were Male BNC.
Thanks for the help thus far everyone.
Old 2nd September 2013, 03:08 AM   #9
You should have a calibration point you touch your probe to (looks like it may be on lower left). That will give you a nice square wave, you adjust the compensation on the probe till you get the squarest square wave possible. The probe is then compensated for all the connections.
Glad I could help.
Protek P-3502C dual-channel 20Mhz scope w/probes $150 dwk123 Swap Meet 0 5th February 2012 01:07 AM
FS: Hitachi V-212 20MHz 2-Channel Oscilloscope merlin2069er Swap Meet 1 4th January 2012 12:30 AM
Hameg 205-2 20mHz Storage Oscilloscope + Brand New Probes (London) thermionic Swap Meet 0 7th January 2010 07:35 PM
iwatsu scope manual ss 5712 SUE Parts 1 9th September 2009 04:44 AM
20Mhz dual trace oscilloscope for sale NotInTheMafia Swap Meet 0 23rd October 2005 11:44 PM
Copyright 1999-2017 diyAudio
