B&K 1607 notch filter activated - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 4th August 2013, 12:42 AM   #21
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default Mod pictures to activate the B&K 1607 Notch filter -
Here is my modification work for the active/passive 1607 notch filter. A 2pdt toggle (double contacts for reliable, good contact) switch to select active mode or passive, a 10 turn Spectrol pot with locking mechical turns indicator, circuit board for the opamp hung off the output socket.... plenty of room for batteries inside/below.
Thank you - ghg for the quick feedback/help which makes everything move along much faster for us all.
-Richard Marsh
Old 4th August 2013, 04:10 AM   #22
RNMarsh's Avatar
Default active circuit -
Here is ghg's proof of concept circuit that I then used. I am tempted to use it more often now and the low opamp output Z is helpful in many applications.
The improvement in H2 loss is much better now (only 0.3dB) and helps reduce chance of errors; One less correction to think about or remember.
THX-RNMarsh
Old 5th August 2013, 11:54 PM   #23
RNMarsh's Avatar
Default Details on Active 1607 modifications -
Last details on active mod ----> The batteries will be mounted on a removable rear panel for quick access for replacement.
The front shows the location of the passive-active switch, and added BNC active output, and new locking dial for the new ten-turn balance control.
Now it is fully self contained without taking up more work bench space.
Thx-RNMarsh
Done. Check !!
Old 13th August 2013, 02:34 AM   #24
RNMarsh's Avatar
And, with batteries in place and power on-off switch access via rear opening.
Check !
-Richard
Old 9th October 2013, 01:37 PM   #25
Hi all,
Inspired by GHG's 1607 modification here I'm considering changing a twin-t that I make for an HP339A oscillator variant (courtesy richiem's webpages) into a passive/active one.
I've calculated some values that should make it possible to switch between 20 Hz, 1200 Hz & 12 kHz (for 48 kHz multiplas) frequencies. I've drawn up a crude schematic for this (there's just a bit in Danish ). The opamps are not LT1007 but OPA2134s.
Might I have your input on whether or not this is correct - and if I should omit/change something:
- e.g. related to the input buffer?
- or remove the 500 ohm potmeter now that there are potmeters across the resistors?
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 9th October 2013, 03:27 PM   #26
ghg is offline ghg  Austria
ghg's Avatar
Well, you already use three pots for finetuning, no need for the 500 Ohm one.
Regarding the buffer, you have to try out.
Buy the 1kHz osc. from Victor and you should get about -150dBc for h2, see post #11
Have fun
Gary
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 9th October 2013, 04:04 PM   #27
Hey Gary,
Thanks for your feedback ;-) I'll omit the 500 ohms then & try to see how it fares with the buffer.
Have fun
Likewise
Jesper
Old 9th October 2013, 10:52 PM   #28
richiem is offline richiem  United States
richiem's Avatar
I'm not crazy about using the LT1007 as the buffer. I'd choose an LME49710, OPA1641 or LT1468 (using suitable load isolation R) for lowest noise and distortion.
Dick Moore
Old 10th October 2013, 06:29 AM   #29
RNMarsh's Avatar
and, I found the best choice when not sure what to use -- is to start with an LT1468.
-RNM
Old 10th October 2013, 12:43 PM   #30
Hi Dick & Richard,
Thanks for your suggestions but the LT1468 is one of the (few?) of the opamps you often mention that is not available from Mouser. And Mouser IMHO is very convenient to buy from as they take care of all the tax & customs issues which means that a component may cost the Mouser price + 25% tax whereas Digikey typically is (component cost + USD 25)*1.25. It doesn't matter if I were to buy for much money but in this case ... My intention was to start out with the OPA2134 (as I wrote in the post a bit back) as indicated on Dick's webpages for the other active Twin-T version.
Hope that works ...
Greetings,
Jesper
notch filter/shelving filter for Alpair5? mondogenerator Full Range 0 29th June 2011 06:13 PM
Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters dtm1962 Multi-Way 10 8th February 2010 02:17 PM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
SS 6600 tweeter & notch filter Virtalahde Multi-Way 0 16th January 2007 02:01 PM
Copyright 1999-2017 diyAudio
