B&K 1607 notch filter activated - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 29th July 2013, 07:48 PM   #11
ghg is offline ghg  Austria
ghg's Avatar
Perfect, now a new teaser:
Switched the E-MU 1616m to 48kHz and tweaked the notch depth a little bit,
so Victors 1kHz gives now h2 ca. -150dB, h3 -153dB ( see the math #1 )
BR
Gary
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 29th July 2013, 07:56 PM   #12
1audio is offline 1audio  United States
I checked a 1K 10 turn pot and no measurable inductance or capacitance of significance below 100KHz. A good wirewound pot with a good contact material should have the lowest distortion of any pot.
I'll fit mine up with this as well.
The spurious stuff in the plot is from the 1616 power supply?
Demian Martin
Product Design Services
Old 29th July 2013, 08:03 PM   #13
richiem is offline richiem  United States
richiem's Avatar
Just tune the notch to exactly -60dB and then add a couple of zeros to ARTA's calculated values. Don't forget to turn on the 400Hz HP filter in ARTA.
Dick Moore
Old 29th July 2013, 08:05 PM   #14
ghg's Avatar
Well, think so, 50Hz power line, but the switch mode PS of the E-MU has a nasty 60 kHz ( switching f ) spike too, tomorrow I'll fire it up using 4x12V SLA's.
Old 29th July 2013, 09:26 PM   #15
ghg's Avatar
Victors 10kHz
h2 ca. -139dB
h3 ca. -145dB
Gary
Old 29th July 2013, 10:25 PM   #16
I checked the EMU 1616. It uses the AK5394A ADC. That's a key part of how it gets the low noise. I just bought one on eBay to see how useful/practical it is and how funky the control software is.
Demian Martin
Old 30th July 2013, 10:56 AM   #17
ghg's Avatar
Well, hopefully you will get the 1616m, NOT the 1616 -> lower quality AD/DA.
1616m:
ADC - AK5394 (AKM)
DAC - CS4398 (Cirrus Logic)
1616:
ADC - PCM1804 (TI)
DAC - CS4392 (Cirrus Logic)
And the spike at 63 kHz is bad, time to build a linear 48V/18W PS.
Gary
Old 2nd August 2013, 04:31 PM   #18
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Check my input at -- Active Twin-T filter forum regarding the use of a notch filter for similar purpose and other apps using an HP334A
THx-RNMarsh
Old 2nd August 2013, 05:34 PM   #19
Link? (No useful Google Hits.)
Demian Martin
Old 2nd August 2013, 06:31 PM   #20
richiem's Avatar
Build -- Active Twin-T notch filter for distortion analysis
Dick Moore
notch filter/shelving filter for Alpair5? mondogenerator Full Range 0 29th June 2011 06:13 PM
Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters dtm1962 Multi-Way 10 8th February 2010 02:17 PM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
SS 6600 tweeter & notch filter Virtalahde Multi-Way 0 16th January 2007 02:01 PM
Copyright 1999-2017 diyAudio
