tube tester comparison - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 21st July 2013, 04:07 PM   #1
filipp is offline filipp  Greece
Default tube tester comparison
Please can anybody tell me, if you know, which type of these two tube testers
(TV-7/U and TV-10D/U) is better (more usual and functional for mesure and matching amplifier tubes like 12**7 ,6CA7,6L6...) ?
Old 21st July 2013, 08:19 PM   #2
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
Both are trans-conductance meters and just cant match a tube.
If you want to match tubes, get 2 high voltage supplies (anode,G2) another 2 supplies for bias and fillaments. make a nice box whit current and voltage meters. and say 10 of the most common sockets. choose the connections whit banana jumper cables and your all set.
V4lve.
Old 21st July 2013, 08:46 PM   #3
V4lve.
I thank you for your answer and your advice,
may be i try it
Old 21st July 2013, 10:41 PM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Check out Ale's web site. About a quarter way down this page he shows how to test transconductance with a current source bypassed with a capacitor, and a sense resistor (THD, GM, u tester).
valve tester | Bartola Valves | Page 2
Old 22nd July 2013, 09:30 AM   #5
Thank you
Old 22nd July 2013, 09:54 AM   #6
If you make just a DC tester, I would suggest that you use a very stable power supply for the negative grid voltage. As grid voltage error is amplified by quite a lot.
The best thing would be a LM399 referenced supply for the bias whit a 3 stage kelvin varley divider to set the output voltage.
you could then add A balancing network to make the meter read 0. Then you make the grid 0.1V more positive and voila, you have the trans conductance
v4lve
interesting power tube comparison chart speakerfritz Tubes / Valves 2 19th March 2012 01:12 AM
WTB: Tube IMP or VTV Tube Tester or? bmenary Swap Meet 8 24th July 2011 10:39 AM
Help finding a tube tester for Stereo tube amps. Fasterdamnit Tubes / Valves 8 19th July 2010 01:43 AM
Tube Tester jtwrace Equipment & Tools 5 8th September 2007 04:47 PM
tube tester TJ Equipment & Tools 11 5th April 2005 02:23 PM
Copyright 1999-2017 diyAudio
