Mastech HY5005d-2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 28th June 2013, 07:31 PM   #1
Default Mastech HY5005d-2
I purchased this power supply for building amps, it is 50v X2 by 5A. This is the ripple on the output Ripple noise: CV <= 0.5 mV RMS, CC <= 3 mA RMS . This was their linear version would it be a good idea to make a CLC board to go with this for testing? Here is a link to the unit .DC Power Supply - Linear Power Supply - MASTECH LINEAR POWER SUPPLY 50V 5A HY5005D-2 DUAL OUTPUTS (Powered by CubeCart)
BIll
Old 29th June 2013, 03:34 AM   #2
richiem is offline richiem  United States
richiem's Avatar
CLC=? Current Limit Crowbar. or? In any case, I think this supply is fully protected internally against overcurrents and shorts.
Dick Moore
Old 29th June 2013, 05:36 AM   #3
Sorry I ment CRC , a filter bank to clean it up .
Bill
Old 29th June 2013, 05:40 AM   #4
richiem's Avatar
Well 500uV ripple and noise at full output is a pretty clean supply.....
Dick Moore
Old 29th June 2013, 01:55 PM   #5
Thanks,
I had no reference as to whether that was clean or not, I had a smaller supply but it was one of their switching ones and it was and it was audibly noisy. I purchased Pete Millets sound card interface to experiment building amps and wanted to make sure I was not seeing power supply noise.
Bill
Old 29th June 2013, 08:18 PM   #6
richiem's Avatar
I think in this case you can ignore the supply as a source of problems, unless EMI or RFI are being generated. You definitely want a linear supply for doing very low level work.
Dick Moore
Mastech LCR Meter, worth a shot at $60? pjanda1 Equipment & Tools 7 7th April 2010 04:08 AM
Mastech Triple DC power supply rcchavez Power Supplies 0 11th July 2008 12:09 AM
Copyright 1999-2017 diyAudio
