Explain AC voltage measurements - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 27th June 2013, 01:36 PM   #1
AndrewT is online now AndrewT  Scotland
Default Explain AC voltage measurements
I connect a 1uF capacitor in series with a small AC motor.
When I measure the voltage across the combination I see 245Vac.
The voltage reading across the motor is 21.2Vac
The voltage reading across the capacitor is 258Vac.
Why?
If I square the 21.2 and subtract that from the square of the 258, I get the sqrt(answer) = ~245.
How are the phase voltages behaving?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th June 2013, 01:57 PM   #2
Elvee is online now Elvee  Belgium
Elvee's Avatar
The motor has a strong inductive component in its impedance, the capacitor is, ..well, capacitive, which means the voltage vectors generated by the common current are 180°out of phase (in the reactive parts of the components at least).
In other words, the capacitor (over)compensates the motor (in a rather excessive and imperfect way).
With a higher value of capacitor, compensation would be more "perfect", which could make things dangerous: the combination would behave like a resistor having the ohmic losses of the circuit as value, leading to a high current and high voltages across both the motor and capacitor.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 27th June 2013, 02:08 PM   #3
It's a 30Vac motor, so I don't want a high voltage across it.
It will run on very low voltage so I don't mind that "only" 21.2Vac appears across it.
Using a 20r resistor (dropping 1.394Vac) in the circuit I see that ~71mAac is passing around the circuit.
I am going to substitute a 300r for the motor. That will bring the phasors to 90degrees.
Maybe that will show more of what I had expected.
I now see that the almost 180degrees of opposition leads to the diagonal being equal to the supply voltage.
regards Andrew T.
Old 28th June 2013, 09:30 AM   #4
glennb is offline glennb  Australia
Why?
You have a series C L R circuit. The current magnitude through all components is the same. Work out the impedance (Z) of each component at the operating frequency. Vcomponent = I * Zcomponent.
At resonance, where Zl = Zc, the series resonant current becomes I = Vin / Rmotor. This can lead to a very very high voltage across each of the C and L, Vl = I * Zl, Vc = I * Zc.
Glenn.
Old 28th June 2013, 09:45 AM   #5
If my arithmetic is right the phase of the motor current is at ~140degrees to the phase of the capacitor current.
I used the cosine rule to determine 50.3degrees.
That makes the cap vertical @ 258Vac and then down 21.2Vac from there at -50.3degrees gives the supply voltage of 245Vac.
It makes sense to me now.
I had the motor phasor as horizontal thinking of it as a resistive load. That misled me to thinking "how can the cap voltage be higher than the supply voltage?"
regards Andrew T.
Old 28th June 2013, 10:00 AM   #6
TonyTecson's Avatar
just get a step down traffo with 30 volt secondary with the correct current(ampere) rating and be done with it...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
New DC to AC to high voltage AC idea? realflow100 Tubes / Valves 11 25th September 2012 01:20 PM
Some transistor voltage noise measurements fftulip Parts 7 22nd June 2010 10:08 PM
Auto Voltage adjustment--Principle explain GPE Power Supplies 2 2nd May 2008 03:50 AM
Could someone explain the ESL High Voltage DC bias supply to me? jzh797s Planars & Exotics 4 25th August 2006 03:19 AM
Aleph board voltage measurements SteveA Pass Labs 8 21st January 2006 05:30 AM
Copyright ©1999-2017 diyAudio
